Project Optimus Prime
Hey guys couple of quick questions i been wanting 2 change my differental fluid since ive owned tha truck and just havent got around 2 doin it until now. I went 2 tha parts house 2 pick up tha fluid and gasket. my first question is wut weight and brand have u guys used and wut do u recommend?? second question is when i was talking 2 tha guy trying 2 get my gasket i told him wut year make and model it was 4 and he told me he wouldnt change tha diff fluid if it were him cause tha fluid is most likely so old that changing tha fluid would only harm tha diff in tha long run or some nonsense like that and that ended up kinda makin me worry about doing it, so i didnt buy anything and figured id hold off until i got some opinions from u guys on whether or not i should change tha diff fluid. any comments or suggestions would help and thanks in advance guys.
p.s. someone please tell me tha guy was full ![]() ![]() (it would help) LOL!!!!
84 SWB work in progress ![]() ![]() 89 burb 1500 (parts pig) LOL ![]() 08 ford focus (I know, I know) Wifes car ![]() "I said it b4 and i'll say it agian wiring is my worst enemy":devil: ![]() |
Re: someone please tell me this guy is full of BS
Never hurts to change diff fluid as far as I know. About the only thing I think new fluid could do is make some old seals leak a bit, though I've never had that problem with an axle.
Some people say not to change the fluid in an auto tranny if you wait too long, but I'm not gonna be convinced that putting new, clean fluid into a machine will do harm. There again, sometimes, it may make things leak, but I'd rather have the mechanicals lubed properly than keep the old gunk just to cover for a bad seal. You're engine takes oil, just like the trans and diff; would you quit changing the engine oil just because you accidentally waited till 15,000 miles to do it? Last edited by 78 Chevyrado; 12-28-2009 at 01:09 PM. |
3/4 Ton Rodder
I would say he is full of it.
I'm running NAPA brand gear lube in mine.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
Still plays with trucks
That is like saying it is too late to change your oil so you might as well keep on driving with the old stuff. Changing old gear oil in a differential will not hurt a thing.
I like to use Mobil 1 synthetic gear oil. I have seen improvements in power and gas mileage every time I have switched dino gear oil for synthetic. It only costs a little more than regular gear oil and you change it so infrequently that the extra cost is easily recovered by the efficiency improvement. Changing the fluid in an automatic transmission will not hurt it either but doing a chemical flush on an old trans will sometimes make it fail soon after. The flush washes off the build up on the clutches and then the tolerances are too high and things burn up quickly. It just depends upon how much wear the trans had before the flush as to whether it will fail so you are better off not chemical flushing an old trans. A filter change alone will still leave 2/3 of the old fluid in the trans. It will take more than 12-qts typically to fully change out the trans fluid. You can do a full fluid swap by disconnecting the tranny cooler output line at the front of the car and adding fluid as fast as it comes out until the fluid is clean coming out. Do this after installing a new filter and cleaning out the pan & adding 4-qts of fluid to the trans.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
78 chevyrado good point that makes a lot of sense. I think ur right. and on that note wut is a good brand and weight 2 use??? ive seen lucas and royal purple there b4, but i would also like 2 have some more input on weather or not i should change tha diff fluid, it doesnt hurt 2 get 2nd opinions. Anyone, anyone???????
Happy to be here
![]() Join Date: Mar 2000
He's full of it as everyone has mentioned. One other thing is you need to know if you have a limited slip. If so, you will need to add the correct additive to the gear oil.
thanks ken i knew i would hear from u sooner or later. could u or anyone else out there please tell me how i would go about finding out if i have limited slip or not?? as far as i can tell tha truck is just tha bare bones stock 10 bolt no frills diff on it.
Kid's Mechanic
Most older trucks run 90wt, So anything that said 80-90 or 85-90 will work.Might drive it around a bit before you change it to warm it up a bit.If its cool out that stuff is fairly thick and stinks.
Clutch type limited slips are not that common in trucks so the only way to know for sure is to pull the cover off the diff and look at it.
If you do have a clutch type limited slip then use the gear oil designed for it with the proper additives. If you have a mechanical type limited slip like the GM gov-lock or a locker then any hypoid gear oil of the right weight will work. You can use limited slip gear oil in it without hurting anything.
LOL!! that dont sound like a bad idea.
so i can just go ahead and use tha limited slip additive wit out hurting anything? cause i dont really kno much bout axel's or rearends 4 that matter, as a matter of fact i didnt even kno there was a special additive u had 2 add 4 limited silp diff's i thought u just buy tha gasket and tha diff fluid and drain tha old stuff out pop tha gasket and cover back on and add tha fluid back. maybe i should do a bit more researching on this b4 i change tha fluid??????
I put this in mine, no limited slip...
http://www.lucasoil.com/products/dis...id=12&loc=show It's about the same price as the comprable valvolines, etc. Why the limited slip differentials are different is the fact they have actual clutches in the diff case. the friction modifier/additives make change the oil so that the clutches will slip properly instead of chattering while turning. If you have an open (regular, one wheel only spins when you peel-out) it's like you said, open it, drain it, sop out the bottom, reinstall gasket/cover and fill it up. Last edited by 78 Chevyrado; 12-28-2009 at 02:08 PM. |
#13 |
Just get four quarts of synthetic 80W90 hypoid limited slip gear oil and you will be good to go no matter what you have. If you end up not needing the fourth quart (depending upon which rear end you have) take it back.
You don't need a cover gasket just a bead of silicone will do just fine. Just clean everything on the mating surfaces of the housing and cover really well. I like the ultra black RTV. Let it cure for at least a day before you put any fluid back into it so you don't get a leak.
#14 |
Robert Olson Transport
![]() Join Date: Oct 2002
`I am going to disagree with the posters on automatic transmission fluid. If your automatic transmission oil is burnt to where it smells and is black in color the new fluid will make the trans fail alot sooner than if you left it be
Ive seen this happen and had it happen to me several times over the years
#15 |
I would like to thank everyone especialy 78 chevyrado and 68 TT 4 there help and input. I think my mind is made up and im ready 2 tackle tha job hopefully it wont b so hard, ive never done this b4. i think ima try some of tha fully sythetic mobile 1 that 68 TT was talkin about sounds pretty good. sooooooo i dont have 2 use a gasket then???? just silicone???
#16 | |
I have pushed it a few times and filled it up five or six hours later and didn't have any leaks most of the time but sometimes they did. Do the job on Saturday morning and fill it up Sunday morning and you will be OK. I know it has been pretty cold in Dallas the last few days so put a little heater under there and keep it above freezing for the first few hours if you can.
#17 |
Thanks everyone 4 tha help its very much appreciated!!
#18 |
My advice Is never take mechanical advice from a parts guy. I changed mine when I bought it and it looked like chocolate ice cream. I used the mobile one synthetic and had no problems. I would also use a gasket just cause it looks cleaner and it's easier to clean up the next time. Plus they're pretty cheap.
#19 |
I have used rtv and gaskets on them. I used rtv on my dad's truck cuz that's what he wanted, but I used a gasket on my truck simply because I needed to put it together and drive it as soon as I was finished. I haven't had one leak wichever way you go.
If you use a gasket, tighten it to the proper torque specs. If you use RTV, follow the directions on the tube. |
#20 |
just use rtv and synthetic fluid. gaskets leak a lot sooner than rtv. the best stuff to get is called "the right stuff" it cures a ton faster than the standard black rtv and seals better.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#21 |
Where can you find it for sale? I have heard people talking about it but never have seen it on the shelf or used it.
#22 | |
![]() Napa also carries it part number BK 33694. http://napaonline.com/Search/Detail.aspx?R=BK_33694_0006382638 GREAT STUFF!! It is what I always used working in the commercial automotive field. It cures super fast, like one minute. slap it together, fill t up with lube and you are good to go. Just make sure you get the pan and the diff nice and clean. We used a 90* angle grinder and rolock discs to clean them up.
#23 | |
#24 |
Man im really getting hyped up 2 do this on saturday but its been so cold here in dallas that i dont think that tha RTV silicone would cure properly on 40 degree weather. I want 2 but i dunno??
#25 | |
http://www.permatex.com/documents/td...tive/33694.pdf 15 minutes at 70 degrees dry to the touch. It cures with moisture in the air so as long as it is above freezing for 24-hours it will be OK.
