![]() Join Date: Sep 2002
Trouble Finding Fittings
I never thought this would be a problem, but I can't find any tee fittings to run my pressure gauges!
I'm using 3/8" air line to the bags and planned on using 1/8" line for the gauges. The best I could find was at Suicide Doors. They have a 1/2" x 1/8" union tee. My bags are all single port, so I can't use them to run the lines to. What the hell am going to do!!!??? ![]() ![]() |
Re: Trouble Finding Fittings
http://www.*****************/catalog/...-gauge-fitting
plug one port ... PTC 3/8" NPT to 3/8" tube on 2 ports ... [img]http://www.*****************/files/imagecache/product_list/Brass_Tee_with_Straight_Fitting.jpg[/img] Last edited by Shane; 12-28-2009 at 02:56 PM. |
you can use what is posted above or you can drill and tap your T fittings and put in a 1/8" line fitting into the T
#4 | |
I found a way to do this. I picked up some 3/8" x 3/8" x 1/4" compression tees. The 1/4" port is just a hair larger than 1/8" pipe thread. I re-threaded the 1/4" port and used 1/4" NPT-1/8" compression fittings, the kind used for oil pressure gauges. The new threads are perfect. I would still like to know how others connect their gauges to their systems. |
I have had great luck with www.hoseandfittings.com.
http://shop.hoseandfittings.com/catalog/Fitting.html
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
3DrDwn--the 'burb not the band
I usually drill and tap but your local Parker Hanefin dealer as all kinds of stuff. Look for parker under hydraulic supplies in the yellow pages.
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
Parker stores are life savers. The one in Phx are track sponsors and are very helpful any car questions
1973 C10 "Chain Reaction" Street Trucks cover Feb 2012 2013 Silverado 1964 Cadillac |
It'd be alot cooler if you did
As stated above, I just drill and tap where ever I need to.
I carry these... Easy street Tee
![]() The picture doesn't show it but they come tapped with 1/8 thread for the gauge fitting. They run $9.80 each and you will need some 1/8 PTC elbow or straights
Adam M STX Designs Motorcycles | Choppers | Hotrods |
