Old 12-28-2009, 05:18 PM   #1
Matt Man
Matt Man's Avatar
how do ?
how on earth do coil spacers work? im looking to do a 3 inch coil spacer on my truck and i have no idea how they work... i know what they do but does anyone have pics of them installed?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 12-28-2009, 05:44 PM   #2
kev2809
low n' slo
kev2809's Avatar
Re: how do ?
they slide between the springs and it kinda stretches out the spring i guess you could say. my friend had some on his accord when he put 20's on it. they were only 1" but it did raise it up a little to clear the tires
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 12-28-2009, 08:41 PM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: how do ?
If it's a 3" coil spacer than it is probably just a block that goes in between the spring and the upper spring pocket. See pic #1.
They also make twist in spacers that go betwen the coils of the spring itself. They are generally known for making the ride a little harsh and are prone to failure. See pic #2.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-28-2009, 09:05 PM   #4
kev2809
low n' slo
kev2809's Avatar
Re: how do ?
i think your right. the twist in ones was only an inch, the 3" block makes more sense to install in between the spring and spring pocket
-_--_--_ _________
Old 01-02-2010, 07:47 PM   #5
PJsthnam
PJsthnam's Avatar
Re: how do ?
to bad these are for jeeps...great concept.
http://store.jksmfg.com/merchant2/me...de=Coil_Spring
72 GMC Custom Camper
84 Shovelhead
PJsthnam is offline   Reply With Quote
