Old 12-28-2009, 09:55 PM   #1
tswore
built not bought
tswore's Avatar
gas tank in square short crew
Hello, all. I am about to embark on my build, crew cab long box dually to crew cab short box single. I have seen that the tanks wont work after I shorten the frame. What do I use? Suburban? Blazer?? help! thanks fro your help, pics to come.
tswore is offline   Reply With Quote
Old 12-28-2009, 11:54 PM   #2
kelgar50
kelgar50's Avatar
Re: gas tank in square short crew
Blazer and Burb tanks fit nice between the rails or you could use some tanks from a shortbed and that should work good as well.
kelgar50 is offline   Reply With Quote
Old 12-29-2009, 02:00 AM   #3
tswore
built not bought
tswore's Avatar
Is the sender and the pump interchangeable with the sender and pump in the short trucks or the blazer/burbs? mine is a 1991 with the 454.
Old 12-29-2009, 04:02 AM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
If you use the 16 gallon saddle tanks yes.
if you use the blazer/burb tank, no. because of depth differances.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-29-2009, 08:25 AM   #5
lakeroadster
The 'burb tank will hang down pretty low and be visible fromt he back of the truck. Some folks don't like that. If you don't like that look you can do a custom installation like I did.
See posts no. 8 & 29 in my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=363509
First photo below is the 49 chevy passenger style fuel tank,
2nd photo is a Suburban style fuel tank
3rd photo is my truck with roll pan installed, tank can't be seen from rear.
lakeroadster is offline   Reply With Quote
Old 12-29-2009, 11:56 AM   #6
joe231
joe231's Avatar
How are you going to do the frame?
just going to shorten it, or graft on a short-bed rear section?
the reason I ask is I found out the hard way that the DRW hangers locate the leaf springs closer to the frame that the SRW ones do. So if you are shortening the frame, you will either need to swap hangers or move the saddles on the rear axle tubes in-board
are you going to keep it 8 lug?
CHEVY ONLY
Old 12-29-2009, 12:03 PM   #7
BGRAFX
Check out ojoe's or suicide63 build threads.
BGRAFX is offline   Reply With Quote
Old 12-29-2009, 06:29 PM   #8
tswore
built not bought
tswore's Avatar
The plan is to shorten the frame, I can probably round up some hangers without too much trouble.
