12-29-2009, 12:26 AM | #1 |
Big and littles tire size?
I have a good set of 275/60 15's for the rear of my 64 gmc shortbed, I am wanting to do the big and littles look for the tires. 15x7 aluminum slots. What tire size would work best for up front? any suggestions?
1982 K10 SWB 1987 V20 - Sold - Doh! |
12-29-2009, 02:53 PM | #2 |
Re: Big and littles tire size?
The 275-60 is 28" tall. So something a little shorter w/o being too short would be a 215-70 @ 26.85", a 205-75 @ 27.1, or a 215-75-15 @ 27.7" tall. What width wheel do you plan for the rear?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-29-2009 at 02:54 PM. |
12-29-2009, 03:06 PM | #3 |
I would think a 7inch wheel would be too narrow for a 275/60 tire, I have a 235/75 on 8 inch rims on rear of my 64 stepside with a 205/75 on 6 inch rim on front.
12-29-2009, 03:08 PM | #4 |
I'm planning on-
275/60 rear (~28 tall 10 wide) 235/60 front (~26 tall 9.5 wide) Tire rack list diam & width (and other stuff) if you click on 'specs' David |
12-29-2009, 08:24 PM | #5 |
Thanks for the input, I was told the wheels were 15x7 all around when I nought them, I havent measured them though, they are all certainly sitting on 275/60s.
12-29-2009, 08:54 PM | #6 |
Hey 250,
The minimum recommended rim width for a 275/60R15 is 7-1/2. An 8-9 would be better. 9-1/2 is the max recommended. (Tire and Rim Association standards) TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
12-29-2009, 09:14 PM | #7 |
Senior Enthusiast
Here’s what 215/70-15's look like on 15x5 TTO rims:
And here’s what the same tires looked like previously on early Dragmaster 15x6" rims: If I had it to do over again, I’d run the 15x7 TTO’s (like what is on the back) all the way around with the 215/70 tires on the front. The extra width of the rim is almost all to the back (more backspacing), so the wheels wouldn’t stick out further, but the tires would look more stretched out over the rim (which I prefer). I can’t check right now but I think my rear tires (on the mags) are 255/60-15. |
12-29-2009, 11:25 PM | #8 |
I have 8" rims all around on my '65 step side . I originally had 225/70/15's on the front and 275/60/15's on the back . When I recently replaced the tires , I switched to 255/70/15's on the rear for more clearance . It is a good combination .
12-29-2009, 11:34 PM | #9 |
Here they are, the supposed 15x7 on the 275/60s. I'll double check next time I'm out in the garage.
12-29-2009, 11:50 PM | #10 |
I used 8.5's with the 275/60R15's on my old '78.
In the picture, it looks like they could be 7's given the way the sidewall is pulled into the tire. Deffinately not recommended if they are 7's.
Don't let my username fool you, I have become brand blind. Cool is cool, period. 1965 C-10 - "Whipping Post" 1958 Biscayne - "Ruby" 1961 IH Scout 80 - "Gaucho" (My wife's new project) 1938 Chevy - unstarted project. |
12-30-2009, 09:00 AM | #11 |
Love the look of slots on these old trucks! Sweet!
Anything smaller than a 28 inch diameter tire in the front doesn't visually fill the wheel well opening up, IMHO. That was about what these trucks rolled out of the factory with. Your thread title is "big and littles" which is old school. Being an old fart I am qualified to state that old school also would dictate wider rims in the rear than in the front and rubber that shows a lot of sidewall. As a visual reference I am running 15 x 8-1/2's in the rear with 15 x 7's in the front. 235/75R15 front and 33x12.5R15 in the rear. I hope this helps you in making a decision. |
12-31-2009, 01:55 AM | #12 |
Sunburst C10!!!
i have 275 60 mt drag radials on an 8 in rim
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 12-31-2009 at 02:00 AM. |
