Old 12-29-2009, 11:01 AM   #1
samdjr74
58 Cab gas pedal, what are you using?
Hi All,
I have a 58 cab on my 56 Chevy and I need to start looking for a gas pedal soon. I don't have the original and was wondering what you guys are using, original, aftermarket? What works best? I'm running a 350 in the truck so the stock carb set up is gone if that matters.
Thanks,
Sam
samdjr74 is offline   Reply With Quote
Old 12-29-2009, 02:22 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 58 Cab gas pedal, what are you using?
the one from a 72-87 is cable and fairly easy to install
dwcsr is offline   Reply With Quote
Old 12-29-2009, 03:12 PM   #3
samdjr74
Thanks Dave, I'll take a look at them.
Old 12-29-2009, 03:14 PM   #4
Wrenchbender Ret
I use the original one. The linkage comes in a kit & the pedal has the hinge encassed in rubber & bolts to the floor. I don't like it. Next time I'm going to do like DW says & adapt the later model with a cable.
Wrenchbender Ret is offline   Reply With Quote
Old 12-29-2009, 03:40 PM   #5
samdjr74
I was looking at going with a lokar but their prices are a little too high in my opinion. I can't find the original one for my truck so I figured looking at eiher used or adapting is the best bet. Sounds like you guys agree.
Old 12-29-2009, 07:26 PM   #6
OrrieG
OrrieG's Avatar
Stock 58-59 V8 rod and pivot through the firewall. I tossed the pedal that bolts the floor, just use the rod end it attached to. You can see it in this photo, behind the steering.
OrrieG is offline   Reply With Quote
Old 12-29-2009, 08:13 PM   #7
renegade6
If I remember correctly, I'm using a pedal and a cable from a 80s Chevy van.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 12-30-2009, 10:50 AM   #8
Kateaux
Kateaux's Avatar
I am using the Lokar billet aluminum pedal. Nice piece and easy to install.
K8O
1958 3100 w/55 frontend and 55 Cameo Bed (in progress)
Kateaux is offline   Reply With Quote
Old 01-04-2010, 09:04 AM   #9
samdjr74
K8O
Which one? It looks like they make a couple different models.
Old 01-05-2010, 02:54 AM   #10
MrSinister
MrSinister's Avatar
i'm using the lokar eliminator. the one that mounts under the floor, was easy to install and cleans up the firewall
'56 Big window
350/700r4
9" rear w/disc
MrSinister is offline   Reply With Quote
Old 01-05-2010, 11:32 AM   #11
blackdiesel
blackdiesel's Avatar
i imagine with a little bit of engineering you could make nearly anything work. i put a camaro motor in my pickup and installed the camaro accelerator. little heat to bend the rod to the right angle and a few bolts to secure it to the floor. if you dont have axcess to a donor car or junk yard i have installed the aftermarket universal ones too, same thing only more$$$$
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
