Old 12-29-2009, 11:45 AM   #1
66scottey
Question 66 c 10 lwb to swb?
i have a 1966 chevy c-10 4x2 lwb and wont to make it a 4x2 swb what is the best way to do this i do have tools need to cut and weld etc
66scottey is offline   Reply With Quote
Old 12-29-2009, 12:03 PM   #2
SCOTI
SCOTI's Avatar
Re: 66 c 10 lwb to swb?
He did an excellent job @ this very conversion....
http://67-72chevytrucks.com/vboard/s...d.php?t=333241
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-29-2009, 12:26 PM   #3
66scottey
thank you ill check it out but i wont to keep the rear coils could i weld the whole mount
Old 12-29-2009, 01:21 PM   #4
SCOTI
SCOTI's Avatar
No reason you can't still use the coils (he just switched to bags for his build). The frame cuts & bed cuts needed for the lwb to swb conversion still apply.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-31-2009, 05:21 PM   #5
66scottey
Question Re: 66 c 10 lwb to swb?
ok now i have been pondering and i dont know if i wont to cut the frame or if i wont to keep it a 4x2 or make it 4x4 is there a good doner truck frame to make it a swb?
Old 12-31-2009, 06:48 PM   #6
SCOTI
SCOTI's Avatar
Any 63-66 swb frame would work. Later frames can work, but will add to the complexity of the swap (cab mounts are in a slightly different location, radiator core support mounts in a different location, & the front frame horns are different).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
