Bed Liner Coatings
Have any of you guys use any Roll in Bed Liners? Off the Shelf kinda stuff..... Hippo Liner, Herculiner, etc. Would like to hear of any experience you guys may have with any of this.
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: Bed Liner Coatings
This has been discussed many times. I will answer according to what I have seen in the numerous topics before to help you out pretty quick.
THE BEST: Line-X The Best do-it-yourself: Raptor, SEM, Grizzly Grip, and then there is one other type on here that others have used that I have heard good stuff about. I have used SEM, Herculiner, Grizzly Grip and that really cheap stuff at Wal-Mart on jeeps and trucks in the past. So far, SEM is the best I have personally used. It can be tinted to match the color of your vehicle paint. It isn't a real sandpaper type finish like Line-x is, but I wanted one more like Rhino Liner as I sprayed it inside my daily driver Jeep Rubicon tub so I wouldn't rip skin off. Grizzly Grip is also very good. It comes out more like Line-X, more of a rough grit to it. I sprayed it in my old jeep tub, and I never had a scratch or chip in it. It also comes in different colors pre mixed which is good if you don't need a 100% color match. I liked it a lot as well. Herculiner is ok at best, but it can chip and peel easily if not prepped right, but still will after good prep. The Wal Mart stuff is junk, do not waste time on this. Maybe some on here like it, but to me its just a non-skid coating type paint, flakes, chips, and scratches with a fingernail. I try to spray mine on everytime. I just walk into harbor freight and either get a drywall splatter gun, or a abrasive blasting gun for cheap and spray. Prep work is key.
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Its a Truck Thing......
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
#4 | |
No problem,
I am in the same boat..... Smitty
1967 SWB sw
Im also in the same boat, the prep work may be the hardest part for me. Thanks for the help
heres a couple I did with Al's Liner. It can be rolled in but you do get better results by spraying it in.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
#8 | |
![]() Quote:
just like a paint job.....its all about prep...... i scuff my whole bed, then wipe down with cleaner (stuff used before laying paint down) removes dirt,grease etc.... then brush on the tight spots and roll the rest with skinny/wide paint rollers..... let it dry for a couple days and have fun... Last edited by QKENUF4U; 12-31-2009 at 10:51 PM. |
i will likely use al's liner products on all future body off resto's.....good rust/soundproofing for floorboards (top and bottom side), frames, chassis components, hitch, etc. powdercoating doesn't last more than a couple years when subjected to regular winter driving. first off for me will be an 87 ram 50 (mitsubishi pickup) that just doesn't take well to salt spray (rusts like a son of a gun). i may do tinted liner to match the paint....or paint the body with the liner and use multiple coats of black liner in the bed, chassis, etc to differentiate. it's handy having a little truck that can haul the snow blower, snowmobile, haul a small trailer etc when i don't need my 72 burb (or want to keep it out of the salt spray).
I have used Scorpion Brand for the last couple years and have found it to be the best!
It wont turn to flat black, like the others after a year |
I just went through this as well; I was a bit put off about the price of some of these products, as well as concerns about the long term durability (flaking, discoloring, etc).
In the end, I handed my daughter a can of black Rustoleum and a paint brush and told her to "go to town". For about $6.78 I have a nice, black pickup box. I figure if it chips or flakes I can just redo that area. I should be able to repaint my entire box 50 times (or so) for what I would've paid for the aftermarket liners. K ![]() ![]()
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-01-2010 at 11:36 AM. |
#13 |
you are correct, Al's liner is from what I understand the same commercial/industrial grade liner as scorpion, Just Al's liner has been put into kits so the DIY's like guys on this board can do it for themselves without spending all the installation cost.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 01-01-2010 at 01:55 PM. |
