12-29-2009, 03:46 PM | #1 |
landarts
help with motor mounts
I have a 67 c-20 that had a 327 motor in it . I have to rebuild the 327 it blew a rod. In the mean time I have a 1979 250 6 cylinder that I can put in the truck until I get the 327 back together. My question is can I use the same motor mounts from the 327 or do I have to get specific motor mounts for the 250 6 cylinder ? And if I do need different mounts does anyone know where a good place to start looking is ? Thanks for the any help.
12-29-2009, 04:12 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: help with motor mounts
Should be the same mount, it is on 63-66. The only one which are different would be 292 and BB
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
12-29-2009, 06:30 PM | #3 |
The V8 mount is different than the 6
12-29-2009, 06:45 PM | #4 |
65 Chevy
i agree i just did a swap on a friends truck and the mounts where diffrent
12-29-2009, 08:30 PM | #5 |
the top of the frame has 3 holes for the motor mts. does the V8 use the 1st 2 holes closest to the radiator
12-29-2009, 10:18 PM | #6 |
Yes
12-29-2009, 10:53 PM | #7 |
thanks, my 72 was a six, the PO put a V8 in it and the motor mounts are in the last 2 holes, the dist sits too close to the firewall now, can I just move the motor up to the front 2 holes?
12-30-2009, 12:52 AM | #8 |
Just make sure you have the right motor mount frame stands.
12-30-2009, 01:36 PM | #9 |
landarts
Where is a good place to but new motor mounts and stands for the 250 6 cylinder?
12-30-2009, 02:06 PM | #10 |
MANES TRUCK PARTS has them.
12-30-2009, 02:07 PM | #11 |
It will bolt up to the mounts, but the six will sit a few inches to far forward and wont clear the radiator.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin 67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts) |
12-30-2009, 02:16 PM | #12 |
12-30-2009, 02:37 PM | #13 |
It sounds like you have 6cyl stands if there in the last two holes, V8 stands only work in the front two holes. Here is a pic of V8 stands
12-30-2009, 04:42 PM | #14 |
thank you, didn't know that, so I'll need V8 stands now. Will the engine mounts that bolt onto the v8 block that I have with the 6cyl stands now in the truck work with the new V8 stands?
12-30-2009, 04:54 PM | #15 |
12-30-2009, 05:51 PM | #16 |
Member of the longbed union.
Larry from what I understand you only need the right mount, The left one will move up and work on the 6 and the 8, but right one will only work on the 6. But I've also heard that the 6 mount wont work on a 8. I have the set that you need. since my truck was a 283 truck. I dont use the front crossmember anymore. I have a SD member. let me know if you cant get yours to work and will work something out if you want.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
12-31-2009, 02:54 PM | #17 |
landarts
Im still having a problem trying to find the 6 cylinder engine towers online anywhere . I have been able to find the rubber mounts, just not the towers . Does anyone know where I can find the engine towers to go on a 250 6 cylinder?
12-31-2009, 03:15 PM | #18 |
If I can find a set of V8 towers, I'll have a set of 6 cyl towers available
12-31-2009, 04:40 PM | #19 |
Did you try MANES TRUCK PARTS they have them listed on there web site.
12-31-2009, 04:52 PM | #20 |
I do have a pair, can't sell them here but I could list them on ebay if you want.
12-31-2009, 07:29 PM | #21 |
Larry I'll try to get you pics of my V8 tomorrow night sometime, still at my parents. they are the stock stands that came on a 64.
12-31-2009, 08:28 PM | #22 |
would 64 and 72 V8 stands be the same?
12-31-2009, 09:29 PM | #23 |
yeah, the crossmember from 63-87 is the same and so is the stands. only the arms changed through the years
01-01-2010, 07:24 PM | #24 |
If you bolt the six in the stock location for a six you will need to shorten your drive shaft. It is easy to bolt the v8 in place of the 6cyl but the other way around not so much. Unless it is a 4x4 then it wont matter.
01-02-2010, 12:05 AM | #25 |
Dan
The small block mounts are the same mounts as the 6 cyls. exact same. the 6 cylinders just had a little spacer plate that went between the passenger mount and the block. the only 6 cylinder mounts that were different were the 292 mounts, and they only had a different passenger side mount that sat more forward. So if you have small block mounts, you can put a 6 cylinder on them as long as you have the spacer plate. As well as if you have a 6 cylinder (250 or 230) you can take it out and put the small block back in on the same mounts. Theyre the same except the 292's.
1968 C10 Short Fleet - L79 327, th350 1971 Nova - 327, Th350, 3.73 posi 1971 K10 Short fleet - 350/350 1971 K20 longbox - 350, 4spd 1970 Chevelle, Tunnel ram set up 355, th350 1986 C30 Dually, 454/400 1967 Impala 4 door hardtop, Supernatural clone 1968 Camaro, 327, pwerglide 1967 camaro, numbers match 350, powerglide, bench seat car 1968 Nova, Numbers match 6cyl, powerglide 1968 Nova, 327, th350 1970 Impala, 350, Th350 1968 Impala, Numbers match 350, Th350 1971 Chevelle SS, Numbers match 350, muncie |
