Old 12-29-2009, 07:10 PM   #1
64GMCHorsepower
Justified!
Whats a good Accelerator pedal linkage to use....?
OK, i took out the stock pedal and thru the firewall lever...
I then bought a Lokar Eliminator pedal and cable assembly, and I am not happy with it after a couple of months.....
Anyone have any good recomendations, or if not, can you steer me to a company sells the original style pedal and linkage....
Truck is a 1964 GMC Fleetside......Carbed....350....if it makes a difference
Chad
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 12-29-2009, 07:35 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Whats a good pedal linkage to use....?
For original linkage I'd try Tony LILRED66, he specializes in 4-5-6 Chevys and may have what you need:
http://67-72chevytrucks.com/vboard/member.php?u=17302
The other options are ebay, wrecking yard, craigslist, etc.
If you want to return to an original pedal, I'd look for an NOS item on ebay. I bought one of the aftermarket pedals, and within a few months it was bent into a C and started sticking on the ball end of the linkage due to the bad angle. Cheap offshore steel inside, very disappointing.
Since I had already tossed out my original pedal and preferred the early gasser look, I upgraded to a 60's era Cal Custom aluminum pedal with a block of delrin glued to the back to act as a bearing surface against the original ball end of the firewall linkage.
Old 12-29-2009, 07:41 PM   #3
72bigred
Hmm, there are a few options but it depends on what your taste is, there are alot of aftermarket set ups that are really nice. I would suggest actually going out and looking at some products at some rod shops or even a swop meet before purchasing due to quality issues. May I ask why you did not like the Lokar E? I have seen many people use it and are super happy so that was the way I was going to go?
Skez
72bigred is offline   Reply With Quote
Old 12-29-2009, 07:55 PM   #4
70 Suburban
Rods
Or you can do what I'm doin...... install a ls with drive by wire. then you can use that pedal..he he
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 12-29-2009, 08:07 PM   #5
64GMCHorsepower
Justified!
Skez
Well, it seems to be set up for a roadster with a flat floor more than the curved floor of the truck where the pedal would mount......and getting the screws in it was a major PITA......I had a problem getting the full travel out of the linkage....
Chad
Old 09-14-2010, 11:51 PM   #6
60apache
60apache's Avatar
what is the lokar e have a pic or link?
60apache is offline   Reply With Quote
Old 09-15-2010, 10:07 AM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
64GMC, I have the same pedal assy, I would really like to ditch it and use something for my LS that would look and feel right. I have a pedal assy from a 72 that when I get time, I am going to try to adapt it, but I am always looking for a better solution.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-15-2010, 03:12 PM   #8
65Gregg
65Gregg's Avatar
I used a pedal out of a mid to late 80's p/u from the junk yard, it has worked ok for me. All I had to do was drill 3 holes for the mount on the firewall and a hole for the cable.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 09-15-2010, 03:51 PM   #9
Clyde65
Clyde65's Avatar
Hey Greg! would ya post some pics? and tell us about any other mods you had to do?
Clyde65
Rebuild of Clyde
support our troops!
Old 09-15-2010, 10:05 PM   #10
65Gregg
65Gregg's Avatar
I will try to take a picture tomorrow, need batteries for my camera.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 09-19-2010, 09:06 PM   #11
65Gregg
65Gregg's Avatar
I didn't worry about neatness because this area will get Dynamat in the future. All you have to do is mount it where it will feel comfortable and bolt it up.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 09-20-2010, 09:49 AM   #12
Clyde65
Clyde65's Avatar
Gregg,
Did you use that plastic part of the pedal assy in the eng compartment? did you have to "adjust" the rod any?
Clyde65
Rebuild of Clyde
support our troops!
Old 09-20-2010, 10:26 AM   #13
65Gregg
65Gregg's Avatar
I used the complete later model assembly, including the cable and bracket on the carb. The cable goes through the firewall and attaches to the bracket.
65Gregg
Blue long bed
White TBSS
61 Impala
