roller rockers?
what are they and what do they do?
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622 |
Re: roller rockers?
just replaces your normal rockers with a bearing "roller" tip, and it also has a bearing shaft for mounting it, less wear, less friction on the motor
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb Last edited by texasfunk; 12-29-2009 at 08:05 PM. |
#3 | |
Re: roller rockers?
There are actually 2 different types of them.
"Roller-tip" rocker arms are just that. They only have the roller bearing surface where they touch the tip of the valve. They retain the original "ball" at the fulcrum. "Full-roller" style have roller bearings at both points. Just to further clarify, these are internal engine parts that are part of the valve-train
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
