Old 12-29-2009, 09:37 PM   #1
hugger6933
Serpintine help?
Can any one piont me in the right direction for wiring up the alt on mt truck after I go to the serpintine belt setup? the Parts are off a 94 c 1500. Thanks, Jim
hugger6933 is offline   Reply With Quote
Old 12-30-2009, 10:29 AM   #2
Sammy
Re: Serpintine help?
There are a few places. Do a goggle search there are several and you can take a peak at them. The FAQ section on this site has some info too. CS130 alt conversions. (but good info was found on the web too) Depending on what you are putting the Alt in you may also need to rewire to bypass the regulator if equipped plus a resistor in the system. If the resistor is needed do a search and order the proper alt conversion plug. I found pictures of the various 1 wire alt to determine which one I needed.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 12-30-2009, 10:44 AM   #3
Sammy
Painless has the Alt conversion plugs and resistors.
