Badass
dip stick
ok i was putting my headers on and i pulled out the dipstick and cant figgur out how to put it back on? there is a tube sticking out from the block about 1/4inch out and its the same size as the dipstick tube i pulled out?
any help? did i brake it?
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Re: dip stick
sounds like you broke your dipstick tube... time to buy a new one..
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
Badass
Re: dip stick
great.how do i get the rest of it out? put some wd40 to let it sit and pull it out? or not good with it around the oil?
Right turn Clyde
Re: dip stick
Drop the oil pan and tap it out with a screw driver from the bottom up.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
6.0 powered square
Re: dip stick
not to bad if you have some swivel socks and long extensions
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
Re: dip stick
It may come out if you're careful by pulling it out. The wd-40 won't hurt the engine as long as you don't go nuts and fill up the pan. I'd try this first to save pan removal, but even if you break it off to where you can't get ahold of it, tapping it out from underneath will work. Just be careful not to cave in the end of the tube you're tapping on or it will deform and not come out easily.
Looks like you have a 2wd. If you have a small block 350 you can take the pan loose without moving the engine. Just unbolt the pan and if you can't get it out, rotate the crankshaft until you can get the pan out. The front throws on the crankshaft will block you from removing it, so you just rotate the engine until they're out of the way. |
Badass
Re: dip stick
ok good ideas guys, ill try the wd40 first ,the work my way from there
its a sb305 ): with th350.
Project Optimus Prime
Re: dip stick
mine is loose and tha headers are in tha way of tightening it up, i cant get 2 it
84 SWB work in progress ![]() ![]() 89 burb 1500 (parts pig) LOL ![]() 08 ford focus (I know, I know) Wifes car ![]() "I said it b4 and i'll say it agian wiring is my worst enemy":devil: ![]() |
Badass
Re: dip stick
been driving around all morning looking for some place that has a dipstick no luck but i got a tinny one its about 7 inchs long im gona try that
wish me luck
