Carter AFB Rebuild Question
I rebuilt my carb today and have a little bag of important looking stuff left over. Not really, but I did have one part that I cannot figure out.
A little check ball fell out of my carburator while I was taking it apart. There was a new one in the kit, but I cannot figure out where it should go. Any help would be greatly appreciated. BTW - I finally gave up trying to figure it out and put the carb back together and it seems to run great, but I just want to try to do the job correctly. It was a NAPA rebuild kit and the carb is a carter AFB competition series #9635.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
![]() Join Date: Feb 2002
Re: Carter AFB Rebuild Question
The check ball goes inside, under the accelerator pump squirter nozzles.
There's usually a spare check ball in the recarb kit. I use EDEL-1477, it has a lot more parts than the old Carter recarb kits did. In case you were unaware, the Edelbrock Performer Series Carbs are basically the same as the Comp Serieds Carter AFBs. The two companies have different numbering systems for the small parts, but they're basically identical physically. I'm not sure, but I think the 9635 is the same as the Edel-1400, 600-625 CFM w/ EGR. I had one on a 454 in my old '67 K/10 Suburban. After an air cleaner fire, it's just spare parts now, but it was a good carb.
Does it go below the pump discharge check needle? I'm looking at a diagram, and the ball is not shown. There is a brass needle under the pump jet housing - does it go under needle? Thanks.
![]() Join Date: Oct 2007
The Muscle Car TV show just went through a Q-Jet rebuild. Here is a link to te rebuild. The very last slide has the video showing where the ball goes.
Hope this helps. |
Sorry here is the link. http://www.powerblockmag.com/?pub=735fa32c&page=18
If it has the brass needle it will not use a ball at that place. It may be an extra part for some models that use a ball instead of the needle. I can look at a book tomorrow & see. A breakdown for Q-jet's will not help you.
I had hoped it was just an extra part for another model, but a little ball did come out of the carb when I took it apart. Please take a look at that book when you get a chance I would appreciate it greatly. Like I said it seems to be running great. I've driven back and forth down the street and all is well. I'll probably take it across town tomorrow (thrillseeker).
Garage Freak - I'll be driving right through Roswell tomorrow. I'll be heading to Lilburn. I have a Carter AFB so the Q-Jet stuff probably doesn't Jive. Thanks for the link though. I have a Q-Jet I think I'm going to build for backup.
Duh, I'm not sure where I got started on the Q-Jet. I slapped my typing hand.
You are no the first. There is probably a weight that you lost as well. You will want to fix that. It is the check valve for the accelerator pump. It goes under the squirters.
Download the carb owners manual from Edelbrock and look at page 22 part 36 & 37. http://www.edelbrock.com/automotive_...ers_manual.pdf
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 12-31-2009 at 06:37 PM. |
WS6 - Thanks for the link. I thought it came from there, but I didn't think it would have both the ball and the weight (I guess). It looks like the ball goes in first and then the brass weight. The weight has one pointed end and one flat. Am I correct that the weight should go in pointed end up?
BTW - I drove the thing 100 miles today and it worked like a champ. I will make the repair, just hope I don't ruin the gasket.
The chart shows a ball that looks like it goes in the bottom of the accel. pump well. Look down the throat of the carb & work mthe throttle. If you get 2 good squirts of gas I wouldn't worry about it.
#12 | |
#13 | |
EDIT: The more I think about this, Are you sure you are not confusing that weight with the needle for the needle and seat? I seem to remember the weight being the same on both ends. The needle is similar is size and material but it has a pointed end for the seat and a flat end for the float. Be sure to post your results for others that may have the same problem and find this thread. As for the ones saying don't worry about it, That carb has been produced for many many years and it has not changed. It is still in production today. If the weight was not needed the engineers would have removed it long ago. It may not affect him right now but it will rear it's head in the future. All it takes is enough time for the fuel to evaporate and leave a small deposit under the squirter and all of the sudden the accelerator pump is not working because the check ball is gone. Not to mention the headaches for him or the next owner who tries to tune it by changing the squirter size because it is not getting enough fuel from the accelerator pump. It's an easy fix. He should do it while it's fresh on his mind. Not flaming, just my .02
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 01-02-2010 at 11:39 AM. |
#14 |
I just did my 9635 AFB. I used an Edelbrock rebuild kit to do it. The kit came with a ball and weight but my AFB just had a brass needle. I just re-used it. Seems to work fine. I seem to recall reading somewhere that Carter AFB's came with a needle and Edlebrocks use a ball and weight. Must have been a minor design change somewhere along the line.
1970 C10 LWB with SB 307 & TH350 |
