Old 12-30-2009, 01:24 PM   #1
s_nova69
C notch questions
I am starting my C notch (weld in) in the next few days and am wondering if there is concern for supporting the rear portion of frame behind the axle to prevent warping/misalignment. If I do need to worry there what the heck can ya do to support it while installing the notch? This is on my 72 c-10 short super build. It has rear coils.
Phil
'70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver
'72 short super build
4wd '72 Suburban LT4 coming soon!!
s_nova69 is offline   Reply With Quote
Old 12-30-2009, 01:25 PM   #2
s_nova69
Re: C notch questions
Oh ya it is currently just a chassis w/o body on it. Thanks Phil
Phil
Old 12-30-2009, 01:33 PM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I would just cut it and weld in your notch....if you are woried then tack weld a piece of angle iron on top of the frame rail that wil stop it from doing anything funny....just be sure to put your jack stands in front of the axle
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 12-30-2009, 04:03 PM   #4
bagged81
Signals in the bumper.
bagged81's Avatar
Weld the sides and top of the notch to the frame first. Next, cut the frame out from the notch.
Jeff C.
1981 Chevrolet Silverado - Under major construction...again. link
1962 Chevrolet Impala 4D Sedan moredoorclassics.com
1936 Ford Pickup - Frame-off in progress link
1979 Chevrolet Camper Special Flatbed link
bagged81 is offline   Reply With Quote
Old 12-30-2009, 09:43 PM   #5
Luv68's
Luv68's's Avatar
What he said, just notch the sides of the frame slide the notch in. Make sure you have a good tight fit, weld it up and then cut the frame away in the middle of the notch. That way there is very little chance of getting anything crooked or drooping.
Luv68's is offline   Reply With Quote
Old 12-30-2009, 10:11 PM   #6
Hottrucks
Hottrucks's Avatar
he did say C notch didn't he?? I guess this falls into that catigory of not clear is it a 2" or 10??
Old 12-31-2009, 02:19 AM   #7
MXmaniac
MXmaniac's Avatar
I don't see a need for extra support for a C-notch. But if its a step notch, that's a whole other animal.
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 01-04-2010, 06:57 PM   #8
s_nova69
thanks for the answers. I just went for it and I dont feel like it moved any. Here is a pict of whats done so far.
Phil
Old 01-04-2010, 07:17 PM   #9
Hottrucks
Hottrucks's Avatar
I'd like more info on that sway bar and how well it clears with the notch??
Old 01-04-2010, 11:36 PM   #10
s_nova69
The notch on the dr side is complete. The sway bar is an Aadco and is for an ~82-93 camaro rear. I used a thread from this site to install it and it looks great. The sway bar will have a close clearance on the rear facing horizontal portion at the rear of the notch. I havn't compressed the suspension enough to see what it will really do but will soon. I intend on pivoting the horizontal portion angled downward maybe *15-20 to help clearance. It should be fine. I will get some picts of the clearance tomorrow when I start the other side.
Phil
