Old 12-30-2009, 05:55 PM   #1
southwilrise87
bolts for motor mounts
I finally got my engine dropped in and im that much closer to gettin my truck on the road but I only have one problem. I have the motor mounts resting on the frame mounts, but I still need the two single bolts that go up through the frame mount into the engine mount. Ive tried like two or three different sizes but none of them fit. What size is it? Is it course thread or fine?
southwilrise87 is offline   Reply With Quote
Old 12-30-2009, 06:19 PM   #2
padresag
Re: bolts for motor mounts
what eng are you putting in and what came out
ron
padresag is offline   Reply With Quote
Old 12-30-2009, 06:26 PM   #3
southwilrise87
the PO had a 350 in it and Im putting in the 305 from my old camaro.
Old 12-30-2009, 06:38 PM   #4
padresag
a couple of questions. there are 3 holes on the top of the frame where the frame perches go. are they mounted in the frt 2 holes or the rear? are you still using the 3 speed and is the rear eng mounting under the bell housing?
ron
Old 12-30-2009, 06:57 PM   #5
southwilrise87
theyre in the rear holes. Im using the original 3 speed. Im not sure what you mean by the rear engine mounts. The mounts Im using are the 2 on the frame. The engine is in, I just need to know what size bolts connect the frame perch to the mount on the engine.
Old 12-30-2009, 07:09 PM   #6
MacAttack
283 Drama Queen
MacAttack's Avatar
3/8-16 (course thread) x various lengths (depending on your access from below) , usually 2 to 2-1/2 inches long: GRADE 8 ONLY (bolts, nuts and washers).
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 12-30-2009, 07:31 PM   #7
padresag
rear eng mounts are the ones that bolt off of the bellhousing
the single bolt that connects the frame perch to the motor mount is a 7/16nc bolt.
there was a reason why I asked you those questions,but I guess that you already seem to know everything already, I will stop here.
ron
Old 12-30-2009, 08:33 PM   #8
padresag
mac, that bolt is 7/16nc. there is no requirement at that position for a grade 8 bolt. a grade 5 bolt should have more shear strength than a rubber insulator( which is usually which fails)
ron
Old 12-30-2009, 11:40 PM   #9
damnyankee36
damnyankee36's Avatar
ron
But, grade 8 is the correct grade as supplied from the factory although I agree, I think it's overkill. You would have a hard time getting enough torque on 7/16" bot to get the proper stretch.
In fact, I just discovered a couple days ago that one of my motor mount threads are stripped. Never saw it coming, never came close to tightening. The bolt threads, (grade 8) looks perfect.
damnyankee36 is offline   Reply With Quote
Old 12-30-2009, 11:43 PM   #10
msgross
msgross's Avatar
did you use new "made in India" mounts? some of those suckers have metric holes or just plain crappy threads...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-31-2009, 05:32 AM   #11
southwilrise87
i bought the mounts from napa, it said made in china on the box.....ya i know. the two previous sizes mentioned in the post both didnt fit right. i guess im going to have to guess and check what will fit and what wont
Old 12-31-2009, 10:54 AM   #12
padresag
there may be rubber in the holes from the vulcanizing process
ron
Old 12-31-2009, 03:36 PM   #13
southwilrise87
thanks for everyones help. a 10mm metric bolt fit. put it in and tightened it up and pulled it back out to check. no damaged threads or metal shaving so i found the one. who woulda thought a metric bolt? thanks msgross for the suggestion
