Old 12-30-2009, 06:52 PM   #1
6D8_C10
6D8_C10's Avatar
LSx motor mount question
Ok, I am going to put a 5.3L in my truck. I was doing a little research on a few sites about the install. I was just reading an article in Classic Trucks where a guy was putting in an 5.3L in his '72. He talked about having an issue with the motor mounts. He said his original 350 was in the 1st two mount holes (closest to the firewall) and the distributor was too close to the firewall. He said that most other c10 that he saw had them in the last 2 holes closest to the radiator.
So, I went out to look at my set up, and my motor mounts were also in the 1st or most rear 2 holes closest to the firewall. Yes, my distibutor is right up against the firewall.
So, will I have issues with putting in my 5.3L?
Do I have to move the 5.3L forward?
If I do have to move it forward, that means I would have to move the transmission forward (for th350 trans) and lenghthen the drive shaft.
Or, if I put in the 4L60e I will not have to lengthen the driveshaft just move the trans mount?
68 c10 350/th350 winter daily driver
90 Nissan 180sx, sr20det gt2871r turbo, track car,summer daily driver
"Just so we are reminded of those who are held back,
Up front there ought to be a Man in Black". Johnny Cash.
6D8_C10 is offline   Reply With Quote
Old 12-30-2009, 09:02 PM   #2
Thealien
Thealien's Avatar
Re: LSx motor mount question
4WD usually used the rear engine mount holes to give additional clearance between the engine crossmember and front differential. I have a 4WD and will be using the forward holes for a different reason. There are many people doing these swaps and you should have no problems. Spend some time looking at the thread linked in my signature and you should be able to find out all the information you need.
Old 12-30-2009, 11:20 PM   #3
6D8_C10
6D8_C10's Avatar
Well, my question is do I have to move the mounts to the forward position or can I still use the rear position?
Because, If I have to move it forward it will require a lot more mods.
Old 12-31-2009, 08:13 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
if you have a 9" TH350 (tail housing length) you will not have to shorten the drive shaft assuming you keep the face of the tranny in the same place.
http://www.tciauto.com/Products/TechInfo/trans_dims.asp
68C15 is offline   Reply With Quote
Old 12-31-2009, 09:17 AM   #5
Thealien
Thealien's Avatar
Yes you can use the rear mounts but you will have many more questions. Did you read any of the thread I linked to?
There are adapter plates that put the engine in the stock location, forward 1 inch, rearward 1 inch along with all kinds of custom aplications. If you do a little reading you will find out everything you want to know. I did weeks, months of research and put it all in one place to try and help others with these swaps.
If you want to keep your stock transmission (which has been discussed recently) you will need either an adapter or a certain flywheel. If you want to go with an overdrive which are all longer (except the 200) you "may" want to move the engine forward. Do you want to use a clutch or electric fan? If you want to use a 700R4 you need a TV cable so you would need a Drive by cable instead of a drive by wire throttle body (although I did see one installation where an ingenious person installed the TV cable to the drive by wire pedal). By spending some time reading the FAQ links in that thread you will find a bunch of questions you hadn't thought to ask.
Good luck you will like the 5.3. I haven't read one person say I wish I hadn't done it. It can get expensive if you are not prepared to do a lot of it yourself (harness, fuel pump or tank, electric fans and or new radiator).
There are a couple of build threads in that link where these swaps were done on the cheap (around $2000+ I think) but I see many in the $4-5000+ range. I am just trying to give you all the information you need.
Old 12-31-2009, 11:19 AM   #6
6D8_C10
6D8_C10's Avatar
I found what I was looking for at the very end.
Here is what I found.
The engine mount locations are about 4 inches more to the rear on Gen III/IV blocks compared to Gen I. If you need to bolt a Gen III/IV motor in where a Gen I SBC once was, companies such as Turn Key Engine Supply and Advance Adapters sell conversion plates that bolt to the four holes in the Gen III/IV block and also provide the traditional three-bolt mounting pattern for Gen I SBC motor mounts.
So, from this statement since my mounts are 4 inches to the rear from other Gen I engines i should be able to put in the Gen III in the same place with same mounting locations (minus the adapter plates)
This is really what started this thread is my trans choices.
I have read a lot about the whole flywheel and adapter modes.
I want to go to overdrive. I have a rebuilt 200-4R with a shift kit that I was going to put in my 69 Burb. My truck has the th350 now so it would have been a simple swap with the exception of the TV cable.
But, this is where the motor mounts came into the picture, if I had to move the engine forward I would need to do the other modes so I might as well get the longer transmissions like the 700r/4l60. But, from what I read now I can keep the 200-4r and minimize my other modes.
By the way thanks for your help. I try to do research/read sites, but I guess I just don't ask the right questions or put the right words into a "search".
Sorry but I am more of a visual person and I can see what fits but test fitting and having the parts in front of me. However, this time I don't have that convenience. I am in the Army, working in Indiana away from my home/garage. I will be working out of a co-workers garage. So I can't afford any down time and need to get all the "kinks" out before I even start the project.
So, from the 5.3L I got the full harness. The truck I have already has a electric fan and keeps the engine very cool.
The other thing I need to look into is the fuel pump and tank. I would like to go to under bed tank. And im not sure which is better the in-tank sump or the inline pump.
Thanks again.
Tony
Old 12-31-2009, 12:54 PM   #7
Thealien
Thealien's Avatar
There are so many variables I could write a whole thread right here? I guess first you need to decide budget and go from there. A search from here won't bring up all the info in the thread I have linked because many of the links are to other websites and wouldn't be found. A google search on the other hand would probably find you everything I have put together but I tried to organise and put everything in one place. You will need adapter plates because the gen III engines have 4 bolt mounts and our original engines have 3. There are enough options I know there is something that can put the engine where you need it. The reason I asked about fans is with a clutch fan placement of the engine for fan fitment in the shroud (or making a new shroud) would come into engine placement. With an electric fan as long as you don't hit the fans or firewall you have lots of options.
External fuel pumps can be done fairly inexpensive. About $100-200 for a pump and depending on whether you have a regulator on the fuel rail (depending on year of engine) if you will need the corvette filter regulator. You can use FI fuel line and clamps all the way to AN braided hose and fittings.
As I said so many variables and questions? Some of the build threads will explain a lot visually as you say.
Again good luck and ask any questions you can't find answers to.
Thanks for your service!
Old 12-31-2009, 12:57 PM   #8
1971gmcshortbed
1971gmcshortbed's Avatar
Has anyone used the Moroso plate adapters?
1971gmcshortbed is offline   Reply With Quote
Old 12-31-2009, 01:09 PM   #9
rob32472
use the ece mounts and no issues will you have my friend
rob32472 is offline   Reply With Quote
Old 12-31-2009, 01:31 PM   #10
1971gmcshortbed
Does the ece mount come with everything? The pic is tiny on the website, thank you,
Old 12-31-2009, 01:47 PM   #11
tk-mpl
tk-mpl's Avatar
I used the Performance online engine mounts, tubular perches and trans crossmember package with no issues. I even had enough room behind the intake to mount the PCM and TCM.
Trevor
1968 short box stepside.
2007 5.3L 4L60, tuned w/EFI Live
2005 Silverado bucket seats.
Dominator 2600's all around.
Porterbuilt tubular control arms.
Magnaflow 3" dual exhaust.
tk-mpl is offline   Reply With Quote
Old 12-31-2009, 02:44 PM   #12
rob32472
yes and all you will need to do is drill one hole on each side
Old 12-31-2009, 04:22 PM   #13
1971gmcshortbed
Thanks I just ordered the ece mounts the guy said I would be ok using the Escalade oil pan.. Now for the header issue...
Old 12-31-2009, 04:32 PM   #14
Ackattack
Ackattack's Avatar
I set my stands in the rear position
and then made my own adapters
Ackattack is offline   Reply With Quote
Old 12-31-2009, 05:06 PM   #15
1971gmcshortbed
Do you guys know if the stock ps pump and ac compressor will fit between the frame rails with the ece kit?
Old 12-31-2009, 07:27 PM   #16
6D8_C10
6D8_C10's Avatar
Hey Alien,
I went on your links and found the one where you list the parts for the fuel system.
You list the Corvette regulator/filter as well as the Dorman and Russel parts.
Do you have a link for a diagram or picture of how all this is put together?
Thanks again
Old 12-31-2009, 07:50 PM   #17
Chevy-Art
Chevy-Art's Avatar
How about these?
http://dirtydingo.com/store/American...306/index.html
1990 Chevrolet RCSB●LS1/4L60E
Scrimpin Ain't Easy
I'm not a mechanic, I'm not a tuner. I'm just an enthusiast.​
Chevy-Art is offline   Reply With Quote
Old 12-31-2009, 08:11 PM   #18
Thealien
Thealien's Avatar
Originally Posted by 6D8_C10 View Post
Hey Alien,
Thanks again
In the first post is a link to 2 question and answer threads. In that first post is a link to this thread
And there are discussions showing a couple of peoples set ups.
There are also some pics in the build threads
Old 12-31-2009, 09:03 PM   #19
Thealien
Thealien's Avatar
here a guy modified his sending unit for a return line
And here is his installed setup. His regulator is on the fuel rail so he only has 1 in and 1 out on his filter
All these pictures are from the build threads. Lots of different solutions to the same problem.
Old 12-31-2009, 09:14 PM   #20
rob32472
Yes no issues on the ps pump or a/c
Old 12-31-2009, 09:16 PM   #21
Thealien
Thealien's Avatar
And you can even use your stock PS lines with the new pump by just changing the fittings on the back of your old pump to the new pump.
