Header trouble please help post ur pics
HEY GUYS CAN YOU GUYS POST YOUR HEADERS PICS IF POSSIBLE FROM THE BOTTOM VIEW IM HAVING TROUBLE WITH MINE CLEARING THE TRANSMISSION LINKAGE AND MY CROSSMEMBER THANKS..
Re: Header trouble please help post ur pics
what kind of headers? heres my hedman long tubes, now i have the hedman 3/4 length elite headers if you need pics of that. i konw these pics probably don't help you
i have the megashifter, which uses a cable, not the column, but you can see the pedestal that comes off the frame and the shift rod dangling here.
It seems like those will work because mine dont go all the way under the frame they run right infront of the linkage where the coloum rod goes to..where did you get those headers from
I also have the Hedman LT 3/4" headers and they had no problem clearing. I had more issues trying to install the passenger header around the starter and starter shield.
1971 C-10, 406ci, restoration begun! 406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners. |
