Old 12-30-2009, 09:28 PM   #1
aggie91
I'm just glad to be here!
aggie91's Avatar
brake questions...
I have a rebuild started. I know that I will need to replace the master cylinder since it is leaking down the firewall.
What I am not sure about is the calipers. The fronts are stock truck calipers that were new in 1998 and the rears are rebuilds from a ford versilli(sp?) from the parts store also in 1998. The truck has been sitting since about 2000. Are the seals OK or should I just replace the calipers with rebuilt units?? For safety reasons, I think that I will replace them, but wanted opinions from you guys...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-30-2009, 11:31 PM   #2
Wild83C10
Wild83C10's Avatar
Re: brake questions...
Has it been sitting outside or in a garage? Do you live in a dry part of Texas? I wouldn't think the calipers would be bad even though it's been 9/10 years. I would definitely inspect them at the very least. Make sure you inspect the rubber lines as well.
The rear has disc or drum brakes? If they are drums then the brake cylinder may need to be replaced, those typically go bad before anything else.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 12-31-2009, 01:17 PM   #3
aggie91
aggie91's Avatar
Thanks for the input. It has been outside most of that time. It has discs front on rear. I think that I will put rebuilt calipers on from the parts store. And ALL new lines....
Karl
The LST Challenge:
Old 01-02-2010, 07:09 PM   #4
Wrenchbender Ret
If the pistons push back into the caliper smoothly & the boots are good the calipers should be OK. You can put kits in them yourself.
Wrenchbender Ret is offline   Reply With Quote
Old 01-07-2010, 04:16 PM   #5
aggie91
aggie91's Avatar
Thanks, for only $12 each I can replace the front calipers with rebuilts from O'Reilly's. The rears are from a 1980 Lincoln Versailles the rebuilt ones are expensive or not available. I ordered seal kits, but I may inspect them a little closer before attempting to rebuild them myself.
Karl
The LST Challenge:
