Old 12-30-2009, 10:00 PM   #1
69Special
tire size
From the pic, you'll see that I need new tires. Currently on the truck are 235-65R16 tires. I was going to go with 235-70R16 tires. 16 in rims, not 16.5.
Is this a good size or can/should I go a bit bigger? Thanks for the help with this.
69Special is offline   Reply With Quote
Old 12-30-2009, 10:15 PM   #2
PJsthnam
PJsthnam's Avatar
Re: tire size
By bigger, do you mean wider? Or taller? I'm running 265/75 16's. They're about 10.5"s wide and 32"s tall on stock suspension with plenty of room. Looks like a 3/4 ton truck. Are the size yer running now rated for your truck? (meaning load range?)
72 GMC Custom Camper
84 Shovelhead
PJsthnam is offline   Reply With Quote
Old 12-30-2009, 10:34 PM   #3
69Special
Re: tire size
Thanks for the reply PJ.
Well, I guess I meant both. So the 265/75 16s might work well on mine.
Yep, it's a 3/4 ton. In fact, mine too is a Custom Camper.
You know, I haven't even seen the truck in person. I'm guessing those tires are NOT rated correctly. haha.
Are there any brand/make/style tires you'd recommend?
Old 12-31-2009, 01:12 AM   #4
Sinister
Between Trucks...
Sinister's Avatar
Re: tire size
I'm running 265/70R16's
Here's an old pic
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
