Old 12-30-2009, 11:27 PM   #1
TR65
TR65's Avatar
Hood Spring Removal and Install
I needed to take my hood hinges off for cleaning and painting. There are a number of interesting methods on the board about how to do it. Here is what I came up with.
I took a piece of 1-1/2" X 3/16" angle 9" long and welded two 1/8" thick clips on the ends. The ends of the angle are cut at 5 degree angles parallel each end so the clips will slip into the spring coils when the spring is extended.
I clamped a bar to the flange where the hood attaches so I could operate the hinge. Expand the spring by "closing" the hood, slip the angle into the spring. Then when you release the spring by "opening" the hood the spring doesn't compress and you can take it loose. Reverse the procedure to install the spring.
I used my enging hoist to extend the spring and remove the tool and to extend the spring to put the tool back in.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 12-31-2009, 09:27 AM   #2
64GMCHorsepower
Justified!
Re: Hood Spring Removal and Install
Nice, good idea!
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 07-04-2011, 10:46 PM   #3
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
TR65..
Okay you win....thats a great way to do it...
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 08-26-2018, 01:31 AM   #4
Heater63
Heater63's Avatar
Back to the top. Good info TR65, as I did this today.
another option, use a floor jack to stretch the spring. Attach to the front axle and to the jack arm pivot axle. Very safe.
Rather than weld up a jig, I used wooden paint sticks, $1, as spacers. Broken in half and doubled over, each stick made a 1/8" spacer. When all the coils were stuffed and spaced it was perfect length, the spring fit right on. Then you close the hood, and as the spring is stretched further, all the wooden spacers fall out.
With the spring stretched an spaced, you can handle it safely.
No tugging and pulling. No scratching paint with the spring point.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 08-26-2018, 07:08 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
My painter used rags through one end and pulled. Rather than using the T-handle I brought in for his use. They sell it at LMC.
Old 08-26-2018, 09:55 PM   #6
TR65
TR65's Avatar
Heater63,
Excellent idea! Very safe.
TR
1965 C10 SWB Fleet
Two owner
Old 08-26-2018, 09:59 PM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
WhenI did mine, I just used one of those ratchet straps but this is a great idea
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-27-2018, 12:06 AM   #8
Heater63
Heater63's Avatar
Originally Posted by TR65 View Post
Heater63,
TR
TR, Coming from an engineer, I take that as the ultimate compliment. Thanks for starting this string many years ago!
292 + TKO500
Old 08-27-2018, 08:56 PM   #9
PGSigns
PGSigns's Avatar
Here is what I do. With the hood off I pull the rear bolt out, loosen the front one just a bit and rotate the hinge down and the spring is no longer any pressure. Pull the hinge and spring off. To put em back on just reverse the process. Have done this several time works fine.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-09-2019, 11:09 PM   #10
aotte1
Use a racket strap too. Loop some strap around the hook end toward front. Pull strap and hook spring end into slot. Make sure the spring end on the hinge stays in place correctly.
Works easy for us. Hope this helps.
Les
aotte1 is offline   Reply With Quote
Old 12-10-2019, 08:28 AM   #11
nsb29
nsb29's Avatar
Jimmy
That’s what I did as well! So simple Nothing to it
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 12-11-2019, 07:31 AM   #12
PGSigns
PGSigns's Avatar
It is quick and easy for sure. If you are worried about fresh paint just put masking tape down and once you have the two bolts started pull the tape.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-11-2019, 09:55 AM   #13
The Rocknrod
Moderator
I ended up buying the T-handle from LMC, it works.
Old 08-23-2020, 02:42 PM   #14
nadodave
Thanks for the ratchet strap recommendation! I was about to start cutting up paint sticks - which also seemed like an elegant idea and not as risky as welding a bracket (I’m a lame welder). It took me all of 5 min to change both springs once I figured out where to anchor the strap. I had not looked forward to this exercise, but was tired of propping my hood with a broom stick!
Thanks again!
nadodave is offline   Reply With Quote
Old 08-25-2020, 02:21 PM   #15
'65 chevy lover
Jimmy
Yes, this is how I do it!
'65 chevy lover is offline   Reply With Quote
Old 08-25-2020, 09:39 PM   #16
Lunnb
I just take a piece of 1/4” nylon rope , loop it thru the hook and then pull the spring into position with one hand .
Lunnb is offline   Reply With Quote
Old 08-30-2020, 05:19 PM   #17
Pitpig
I just wedge a piece of jack handle under the end or the spring and instability it like a brake spring
Pitpig is offline   Reply With Quote
Old 11-28-2021, 10:31 PM   #18
1G1YY
I just did this....real simple.
Rear bolt in loosish, tilt back, fit spring, then pulled hinge forward by hand, fitted front bolt....done.
I put a piece of cardboard between inner fender and hinge to protect paint.
I used old springs..
1G1YY is offline   Reply With Quote
Old 11-29-2021, 09:51 AM   #19
hairball
Maybe my original springs are weak but I used a piece of nylon rope with a handle at the end to easily pull them into place.
Hairball
hairball is offline   Reply With Quote
Old 12-02-2021, 11:36 AM   #20
Chevy Fleetside
Chevy Fleetside's Avatar
Jimmy
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
