Old 12-30-2009, 11:28 PM   #1
Jacksons Garage
Jacksons Garage's Avatar
Rear wheel studs on 71 c-10 question
I am replacing the rear wheel studs on my 71 c-10 and am having difficulty locating replacement ones. Their shows only to be one replacement size available through all the usual vendors. The shoulder diameter or "knurl diameter" of the commonly, and only, listed replacement is in the .525 range. The studs that I currently have in my axles have a shoulder/knurl diameter of .622.
I am wondering if anyone has had this different size issue. I have even tried the Dorman site with no luck. I am also reasonably confident that it is the factory rear-end that came in the truck.
My factory stud dimensions are 1/2-20, Shoulder length of approx. 9/32", threaded length of approx. 1 1/8"
Any input is greatly appreciated
Jacksons Garage is offline   Reply With Quote
Old 12-30-2009, 11:38 PM   #2
EyeH8the24
EyeH8the24's Avatar
Re: Rear wheel studs on 71 c-10 question
i have a 71 with the bigger studs . i went to napa with one of mine and matched them up . i will see if i still have the part number in the morning.the ones everyone had listed were to small.
DOH !!!!!!!
EyeH8the24 is offline   Reply With Quote
Old 12-30-2009, 11:39 PM   #3
crushermechanic
crushermechanic's Avatar
i had the same problem with my 71. i went to orileys and matched some up. the ones listed in the book are wrong. i may be able to get you a number tommorrow. let me know if you cant find them.
crushermechanic is offline   Reply With Quote
Old 12-30-2009, 11:41 PM   #4
msgross
msgross's Avatar
autozone has bins of them in the back, just ask them to let you look through them, take a lugnut with you..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-30-2009, 11:50 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
knock one out, drive to napa, and lay it on the counter, tell them you need 10
Old 12-30-2009, 11:52 PM   #6
Jacksons Garage
Thank y'all so much for the prompt response. I was begining to think that I was the only one with this problem. If any of you happen to find the time to get that part number I would appreciate it. I went to NAPA and the guy could only offer me that one part number. I asked to look in the book and found none that would match.
Thanks again,
Rodney
Old 12-30-2009, 11:55 PM   #7
msgross
msgross's Avatar
my NAPA guy doesn't need part numbers... he just walks in the back and grabs it... he's that good...
The Garage:
