Old 12-31-2009, 12:05 AM   #1
into69z
"brand new second-hand"
into69z's Avatar
front cross member change out?
I want to change ou my 69 front drums to later model disc-the best idea I have heard is to swap up to a 91 suburban front cross member (12 bolts I think) and be done with it! No messing around with changing springs and such-no streering changes-has anyone done this particular swap? any problems? I gotta know soon-it's 1/2 price day and pick-a-part this weeekend and it's stuffed with clunker burbs....thanks
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 12-31-2009, 01:05 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: front cross member change out?
You don't have to pull the entire crossmember. I did this with the exact same year burb you're talking about and just bolted to newer arms to the existing crossmember. You can swap the crossmembers, however, if you choose. I think there are 2 holes that have to be drilled and all the others bolts up. 73-87 trucks will work for this swap, as well as 88-91 suburbans.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 12-31-2009, 01:23 AM   #3
extd56
extd56's Avatar
I changed the front suspension of my 1967 from a 8 lug drum brkake to a 5 lug disc brake from a 79 Chevy truck. I unbolted the old crossmember complete and bolted in the new one. I had to drill 2 new holes and enlarge two others, a great swap.
extd56 is offline   Reply With Quote
Old 12-31-2009, 01:25 AM   #4
2tons of fun
do it, well worth it, and you can swap in some good motor mounts instead of the pos factory type.
doing it with a dualy swap right now.
2tons of fun is offline   Reply With Quote
Old 12-31-2009, 01:42 AM   #5
Dustydog
Dustydog's Avatar
Do you replace the master cylinder and brake booster from the donor vehicle as well?
Dustydog
1940 Ford 2D SDN
1970 GMC SB
2004 C5 Vette
Dustydog is offline   Reply With Quote
Old 12-31-2009, 02:16 AM   #6
extd56
extd56's Avatar
Sure did
Old 12-31-2009, 02:21 AM   #7
2tons of fun
dont need to but you can.
i have swapped the m/c both time becuase the m/c was shot on both trucks i have done this to.
if anything you should swap out the diverter/prop valve, on the drum drum setup it was split 50/50 because the front couldnt take as much as disc can. just grab the one from the donor, it will have 2 lines for the front instead of one but you can just block the one off. last time i replumed the whole system and ran all 3 lines fromt he factory mount next to the master. this time i am going to mount the prop ont he crossmember like 73+ and run them from there, it will save some tube and look cleaner.
i am going to keep the small booster on this truck to clear the valve covers better but the last truck had te bigger booster.
Old 12-31-2009, 12:16 PM   #8
into69z
into69z's Avatar
2tons-did you use the same year donor motor mounts(like, if you used a 91 burb, did you use the 91 motor mounts?0 I have a big block truck-any complications? Thanks
Steve
67 Camaro
96 Impala ss-sold
b69:
Old 12-31-2009, 12:19 PM   #9
into69z
into69z's Avatar
Dave2953-are you talking both upper and lower a-arms? did you have to change any other pieces link steering linkage? any other swaps that need to be done to make it right? thanks
Steve
67 Camaro
96 Impala ss-sold
b69:
Old 12-31-2009, 04:58 PM   #10
2tons of fun
yes, the 67-72 mounts are garbage and i refuse to use them. the day i got the truck i wanted to swap them out.
the bases dont line up dead nut to where the motor need to land, i just slip the whole deal in, bolt the tranns to the cross member then the motor will show you were to drill for the mounts.
both truck have been bbc, one was a half ton swap the other is a 1ton/dually swap.
