Old 12-31-2009, 01:18 AM   #1
1969 k/10
1969 k/10's Avatar
starting issues
I have an automatic 4x4 1969 with a 350 that has trouble starting. The starter makes a horrific grinding noise when it is engaged. The flex plate is in decent shape and the starter is getting full voltage. I tried shimming it and had no luck. Any help appreciated.
Thank you.
1969 red k/10 with sb350
4.11 gear ratio, front disk, 3 speed automatic
1969 k/10 is offline   Reply With Quote
Old 12-31-2009, 01:43 AM   #2
dan42
dan42's Avatar
Re: starting issues
How old is the starter? It can only be three things - the shims, the teeth on your flexplate, or your starter.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 12-31-2009, 01:50 AM   #3
67ss&99ss
Andy
Re: starting issues
Some starters come with a roll pin that you can stick between the starter bendix and the flywheel ring gear when they mesh to see if you have the adequate clearance. I believe it is 1/16" or 1/8" in diameter. Maybe someone else knows which of the two it is. I had this issue with my 67 Camaro when I first got it and I shimmed it about 10 different ways and it made no difference. I had to replace the flywheel to fix the issue.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 12-31-2009, 02:10 AM   #4
1969 k/10
1969 k/10's Avatar
Re: starting issues
The starter is brand new and the teeth look good.
Old 12-31-2009, 08:27 AM   #5
cdowns
cdowns's Avatar
Re: starting issues
i'd bench check the starter to make sure it fully extends when energized
Old 12-31-2009, 09:49 AM   #6
dirtyd_nd
Re: starting issues
I had a similar problem and was thinking it was the starter the entire time. The starter would shift after 2-3 starts and then start grinding. It ended up that the starter needed bolts that the shaft was fatter than the threaded area. The only place I could find the bolts that would work were at a dealership. They were $3 total. Hope this helps.
Dale
dirtyd_nd is offline   Reply With Quote
