12-31-2009, 03:01 AM | #1 |
Best price on Mustang II front end? WTB
Ok I think I have finally talked the old man into springing for the Mustang II front end. I remember I used to see them all the time in the Budget trim form for 999.00 but I can't remember where now. anyone know where the best prices are these days for them?
TCI, Heights, Fatman, or ?? Looking for one now so any help would be appreciated!
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
12-31-2009, 11:54 AM | #2 |
Re: Best price on Mustang II front end? WTB
From what I've found they are all within a few hundred $ of each other - usually around $1700 - 1900 for a name brand (complete hub to hub). I saw an off brand MII in a magazine for about $1300, but nothing less than that...
12-31-2009, 02:43 PM | #3 |
A320 Pilot/USAF Retired
Depending on your skill level and how much you want to fab you can get a kit from theses guys for cheap. The guys on "Trucks" put one in earlier this year, looked simple enough.
http://www.welderseries.com/catalog/...hp?cPath=22_25
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
12-31-2009, 06:41 PM | #4 |
I would NOT suggest buying the cheapest IFS (Economy) that is on the market. The cheap stamped lower A-Arms on the economy models are narrowed at the bottom like the original stock Mustang used and necessitated the addition of a strut rod to stop the lower A-Arm from folding back. I have a early model of an economy IFS and my tire hits the strut rod if I turn too sharp. Spend a bit more money and get the full width tubular A-Arms, you'll be alot happier in the long run.
Or you can also look at a unit like this: http://www.stovebolt.com/ubbthreads/...&Number=338344 Scott is on the HAMB quite a bit and he makes a crossmember designed to use S-10 or GM Metric components so you can build the IFS from off the shelf GM parts or even used to keep your costs down. It's an interesting read if nothing else. Last edited by Atomsplitter; 12-31-2009 at 06:44 PM. |
12-31-2009, 08:09 PM | #5 |
here's a thread I started with my choise of mustang 11 that I thought was the best buy. I've got bogged down in the cold and christmas, I haven't got much done in the last month. http://67-72chevytrucks.com/vboard/s...d.php?t=368287
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway Last edited by blackdiesel; 12-31-2009 at 08:09 PM. |
12-31-2009, 08:57 PM | #6 |
Redefining LowBudget
For me its a no brainer..call Scott's Hot rod..there stuff is premio!! priced right and since all of them are custom built IT WILL DO THE JOB....I worked with Jeph give him a call
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
12-31-2009, 10:06 PM | #7 | |||||
well its not really about he cheapest. This is a HUGE step up from what he wanted as was in the process of doing. But getting him from 300 to 1000 was hard enough. I just dont think he can swallow 1700. However if I can get it for 1300 and its the right kit for the truck I might be able to push it that far.... HOWEVER! I have an S10 doner front end in addition to the 67 I have sitting here. So for the S10 idea this might be the best option yet, thanks so much for the link! Quote:
Thank you to all that have helped me with the options here. I am trying to make it right without having to strip the whole truck and start over and thus spending way more then he will be willing to do. or the other route (which is where we were heading) used parts, straight axle or who knows.....thx again! any more ideas we havent ordered anything yet... but im heading back to read more about the s10 crossmember
01-01-2010, 04:06 PM | #8 | |
Edit: Here's the link for a discounted TCI MII: http://www.streetrodparts.tv/tci_mustangII.htm Last edited by MrTucker; 01-01-2010 at 04:08 PM. |
12-31-2009, 10:39 PM | #9 |
just looked though that whole thread on the s10 crossmember idea. Thats for AD trucks. I emailed Dan to find out more though.
01-01-2010, 12:30 PM | #10 |
No dice on the S-10 crossmember. Just got an answer back from Dan. It will not fit a TF truck.
So far I think it's looking like the MII from Speedway 2" drop spindles and Tubular control arm upgrade for 1179.00. I'm still trying to find out the overall track width to see if I need to do the 5/8" narrower contolarms to help with the wheel adapters I will need to reinstall the 6lug slots that are on the truck. If anyone knows the track width on the one from speedway post it or send me a PM. I think thats the last thing I need to find out first
01-01-2010, 01:38 PM | #11 |
I think someone is selling six lug hubs for the MII spindles. Here, http://www.classictrucks.com/tech/09...all/index.html
I checked their website and still haven't figured it all out but it looks like it isn't a very economical solution although it may be a good one. I found this on ebay. http://cgi.ebay.com/ebaymotors/STREE...Q5fAccessories Spendy but it is all the pieces to put the six lug brakes on the MII front end. When you start pricing out individual pieces like wheel bearings, seals, calipers, brake pads and what not it may not be as expensive as it looks. As for myself, I'm intending to use the Welder's series crossmember and Stock MII pieces that I have had out here in the shed for the past 20 years. I'm not out to impress anyone with fancy a arms and am going to run a fairly narrow tire on the front so I don't have clearance issues. Last edited by mr48chev; 01-01-2010 at 02:19 PM. |
01-10-2010, 06:09 PM | #12 |
if you are still looking for a cheap must. II front end. speedway motors out of lincoln makes their own kits. good quality products. just got done installing one in a 51 F-1 for a guy. good for a daily driver but if you are serious about your old truck.. *tracking,racing ect.* then i would look into something beefier.
http://www.speedwaymotors.com/Mustan...Kits,2089.html also, if you plan on putting coilovers on your ride, steer away from carrara's coilover. sure they look nice, but they are such a pain to adjust. if anything, go with QA1's mustang II coilover.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
01-10-2010, 09:01 PM | #13 | |
I got the basic kit (999) upgraded to tubular control arms 5/8" narrowed (1179) brake hoses and rack extentions. all came to just under 1300.
01-10-2010, 11:44 PM | #14 |
yeah, i scanned through this thread again after i posted and didnt realize that speedway was already posted up.
but very nice. pictures are always good! good luck.. pretty easy install! just make sure you have good welds. what did you go for on the rack? power or manual?
01-11-2010, 01:03 AM | #15 |
I'll get some pictures once the parts arrive. Plus I'll be adding the install pics either here or on the build thread in my sig. "Dads Budget 55"
03-21-2010, 12:26 PM | #16 |
Jiim Weimer Hotrod Garage. I got mine with airbags and tubular A-arms for less than $2k shipped
