Some questions about my 71 C10
Hi guys,
im from Germany and i bought me a 71 C10. It have a 400cui engine and a th350 or 400. Befor this car, i had a G20 Van. Now i have all parts of it. My questions: I have no brake booster in my pickup, can i take it from G20? With the master cylinder? I know i have to do some work to fix it on the firewall, but will it run? On the engine is a Edlebrock intake manifold, with Edelbrock carb, can i put the TBI from Van on it? Do the TBi have enough power to run on my engine? On van i have a Th700 wil it fit under the C10? I hope someone can help me. Greetings Andre Last edited by ChevyAndi; 12-31-2009 at 08:55 AM. Reason: Forget a question |
![]() Join Date: Feb 2001
Re: Some questions about my 71 C10
Hi ChevyAndi ... Just thought I would stop in and say
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Hi,
i think i found a nice forum right here. In germany u will find alot about G20 but not about C10 or other. Thank you a lot for your welcome greetings. I think ill find everything here but my english isnt very good, in case of it i have to ask a little bit more. Thanks a lot. |
Your English is probably a lot better than my German.
![]() Search this forum and the world wide web for TBI conversions. It has been done before. However if you have a stock 400, it is really a 402 which is a big block engine. Your van is probably a small block so you will need to find a TBI intake for that big block. I'm not sure if that exists. The 700r4 will work but you will need to make modifications. It also depends on if you have a two wheel drive or four wheel drive truck. ALL trucks were badged (chrome emblem on the fender) C10/C20/C30 even though some of them were actually 4wd trucks K10/K20/K30. However NO truck came from the factory before 1972 with a big block and 4wd so lets assume you have a 2wd truck. I know more about that swap in a 4wd but many folks on here have done the two wheel drive 700r4 swap. Again search can be your friend. Welcome to the forum. You aren't the only person on here with a truck in the fatherland.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
I'M TRUCK CRAZY!
what about a small block 400? could it be that?
THE DAMN YANKEE
Andi, looking at the front of your motor, the left side of the block,where the head meets the block there is a set of numbers and letters. you may need to remove the alt and wire brush that flat area.there should be 3 capital letters like TJZ(THATS MINE) copy them all down and post them or PM them to me and i'll be able to tell you exactly what engine you have also the right rear of the block had a raised serial number casted on the blocAK,(3970010) write them down and get them to me also. you got to know exactly what enging you have. The letters and #s on my block = 350, 4 bolt main 1970- 73. and welcome to the worlds best chevy truck forum! phipp13 in Southern Maryland USA
Hi,
thanks for your answers. Its a small block, the two inner tubes from the exhaust manifold are closer then the other. At big block i think theyr at the same distance. I know the motor code is on the right head, i have to check that when i change the belts. Ill do that next time. So it is a small block, so the intake manifold from van fix? (van is 5.7 with th700) But more necessary is the question about the booster/cylinder. Its realy hard to drive here in town because nobody give attention to my old car. But in looking theyre very great ![]() It is a 2wd I wish everybody a happy new year! Last edited by ChevyAndi; 12-31-2009 at 01:56 PM. Reason: forgot something |
If the van motor is a vortech, then the intake won't fit the 400. You might find an aftermarket intake manifold for the older engine or you could take vortech heads and drill steam holes to put on your 400.
Not sure about the brake question. I would think your original master cylinder should bolt to the booster but booster to firewall will require more. Power brake trucks had a bracket and actuator rod linkage differences from the non power trucks. And welcome! |
Hi,
its no vortech. Yeah, i know the work with the brackets and with the rod. I have learned a metall job about 3 1/2. I have make many calls to shops and have search allot in internet, but nobody can say: this is possible. The guys on the phone says: The brake system is not for booster, you have to high pressure. or You have to change the master cylinder too. |
Hey guys,
first of all i like to show you a pic from my pickup. I spend some time here and searched about the booster/cylinder. I found http://67-72chevytrucks.com/vboard/s...d.php?t=379146 this guy has done, what i want to do. Im happy about that, now i just have to build some brackets. Greetings |
Spanked once
![]() Join Date: Oct 2006
I like the whole truck and color but man I sure would like to see more of the tail gate area, that is neat.
The ole 350 budget build. |
Guten Tag, you will also find more baord members from Germany in our International section.
You should be able to make any brake booster work with some fabrication. The lines might need adapters for the master Cylinder though. There are a lot of "bolt-on" kits or used parts available as well. I'm not sure how much power gain you will see with the TBI, you can ask the experts in our Engine section of the baord though. Welcome, I was stationed in Darmstadt for a few years, love Germany and Europe. Just took my wife on vacation in 2008... she's ready to go back already!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#13 |
@Richard H.: Ill post some more pictures in future!
@msgross: Nice, in past i was in Darmstadt too, but just on vacatation. I have the parts (booster/cylinder). First of all i want to buy so new one but the shipping cost will kill my money ![]() I also need a dashpad cover, its costs 50$ but 250$ to ship it to me. Thats crazy. Next time i build some brackets an usw to use the van combi. Greetings Last edited by ChevyAndi; 01-04-2010 at 01:47 PM. |
#14 |
see if any of our board vendors can ship cheaper... look in the vendor marketplace section... Most of them sell the dash pads and other aftermarket parts.
LMC truck is great for catalog pictures, but not their customer service. Use their website to find the names of what you need. Good Luck... Tschüß
#15 |
Hey guys, long time away, but i wasnt lazy
![]() Just added the brake booster, it was easy but it took me long time to fix the leak in the rear brake line (at the rear end, where steel and rubber go together). I was shocked, at bleeding all the fluid from the mc reservoir run away! searched a long time, it was a 5mm cut from rust. Right in the corner where the line was bend. Its my first car without brake booster and i thought it was normal (hard to stop) but now i know i just had brakes in front! I was on 150kmh on highway, im glad iam alive ![]() The old an the new! Dismounted, dont forget the coffee One bracket, easy but works Attached Booster/Cylinder, painted booster Brakes wonderfull, its a dream, after i finished i drove about 2 hours ![]() One question i have, i got 10,69mpg with 400sb/400, i dont think its normal right? next post for more pics |
#16 |
i build some doorboard for my speakers
The bone (dont know how to call it) out of wood So it will look if its ready its from 1er Bmw e87 Just in polyester, the the speaker box is finished More gfk stuff for the board |
#17 |
Im not finished
![]() Got some seats from 1er Bmw e87 for 20,50€ (the doorboards for 10 and no its not stolen ![]() But i dont know how to make it, 2 or 3 seats? Just cutted the bench, removed 13cm and assembled it to one, upholstery is not my favourite work. ![]() What do you think two ore three seats and why? Last edited by ChevyAndi; 02-17-2010 at 04:24 PM. |
#18 |
Nobdoy like to Answer?
Question to Tbi Swap, i have some 350 out of my G20, can i take the distributor, coil and so on for my 400? Will the intake manifold fix? |
#19 |
nice work so far... not sure on the engine parts, depends on what type of heads on on each engine, Vortech?
#20 |
No, no Vortec, the 5.7 is from 1990 and the 400 from 1971
![]() Im thinking about to build me some adapter plate, then i can stay with the edelbrock intake on the 400. What do you think does the 350 tbi run with the 400? |
#21 |
Chemist under the hood...
Nice work on the door panels. I'm sure the seats will look great. This forum is a life saver. I usually post a question before I start any major work so that I don't make a mistake early on. Your truck looks great.
Take care. ![]()
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
#22 |
10.69 mpg is about all you can expect with a th400 transmission. The very best I get with my th350 is 13 - with a tail wind.
The distributor should work - if it isn't a computer controlled one. Perhaps the best thing would be is for you to post the engine IDs so we know what you got and what you want to swap in. On small blocks there are numbers stamped on the passenger side, in front of the head. There is a small pad where the factory stamped an engine ID and part of the Vehicle Identification Number (VIN). On the back of the block there are also numbers cast in to the engine casting. Posting both will help.
#23 |
Thanks for response,
dont know the number now, its to cold and wet to go outside ![]() But without the number, will the Tbi feed my 400 with enough gas? Do i have to program the chip? The distributor, just a 1990 out of a g20. Dont know if it is computer controlled. Do you drive with carb, on that milage? |
#24 |
I have the numbers (behind the alternator) from the engine out of the C10.
1st: K1121FCU 2nd: CF1135247 (the 7 is original a 6, but it is punched over) Have try to decode it myself, but didnt get it. |
#25 |
Hm, nobody out there?
Is my post so uninteresting? |
