1962 C-10
Heater fan (squirrel cage)
My lady's '65 is missing the heater fan. I was looking and the whole for the fan and it looks very similar to the one in my '73. Is it the same? Will a 73-87 fan work? Has anyone done this? They're very common in our junkyard for $5-10.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 Last edited by jchav62; 12-31-2009 at 11:01 AM. |
Re: Heater fan (squirrel cage)
I am pretty sure the fan fits BUT if the truck still has stock wiring the fan needs to be powered thru a relay for hi position (the origonal fan was permenent magnet an used a lot less power
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
Senior Enthusiast
I have a 1960 recirculating heater, and replaced the original heater motor and fan with one from a Pontiac Fiero. They are dirt cheap and rotate in the correct direction. Not sure about the model you're looking at, but when I did this several years ago I remember putting a lot of focus on having the fan turn the right way. It came down to two choices, the S10 pickup or the Fiero - they both turn the same way. If memory serves correctly everything else rotated the other direction. The reason I picked the Fiero version was because they are all mounted in the the trunk, so they look like new compared to one that's spent a decade under the hood of a truck.
I also used the Fiero plastic fan instead of the metal version. Less weight, no rust and less chance of going out of balance. There was a minor bit of trimming to get it in the case, but it works perfectly with the original speed control resistor. The fan is deeper and of newer design and moves a lot more air on high speed. I've got Ron Francis wiring and none of the stock heater controls, but the relay is a great idea and I'll probably add one just for the extra measure of safety next spring. Here's a rather boring photo of the install through the glovebox opening. The rectangular block to the left is the cruise control module. The rubber hose on the motor is a vent to relieve pressure inside the motor. I don't know where it connected in the Pontiac, on mine is just rests on the heater housing. ![]() |
1962 C-10
Thanks for the info Markeb01! Fan direction never crossed my mind. I'll definitely check into a Fiero fan. I notice that your heater is the recirculating type...ours is the fresh air type... do they use the same fan?
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
Senior Enthusiast
According to the listings on the attached link, they show different motors for the recirculating versus deluxe, and a different motor design between 55-63 and 64-76.
http://www.americanclassic.com/asp/d...to&exyear=1966 When I bought my Fiero motor at the local pick your part, I grabbed two for $5.00 each, including the nylon squirrel cage fan on each. I don't know if they still go for this price, or if it's worth making modifications to accomodate the Fiero fan, but I did it because the original fan was burned out and the steel fan was damaged and out of balance. I didn't really want an original motor since they were 40+ years old. For the price I'd do it again, as I prefer an original GM part compared to the aftermarket parts that may or may not hold up. Hope this answer is of some help. |
I know this is an old post but I thought I would share. I used a fan out of a 2004 ford ranger. It is as quiet as can be and doesn't use much power. I used a basic two speed switch.
