60-66 Braces & Hood Hinges
I am planning on putting in one of Nate's dropmembers and I thought I saw some tubular braces to replace the innner fenders, that also could support the hood hinges.
Thanks, Ryan |
Re: 60-66 Braces & Hood Hinges
Check w/Nathan. He did offer hinges & adapters for pre-67 models.
We have been making a bracket that allows you to run the factory hood hinges and lay frame with up to a 27" tall tire. It comes with the bracketry to run the tubular supports to the core support. I am also working on some cowl mounted hood hinges (like the 67-72 versions we sell) that will work with a larger diameter tire... they will be available SOON.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Nice thanks Nate.
