gas tank
I bought the blazer tank from classic industries and was working on mounting it today. I noticed if I flush the flaps on the sides of tank to the bottom of frame it stiks up over the top of frame about an inch. I am guessing this would be hitting my bed? ALso if I lower it at all my gas tank inlet piper will be in middle of frame. Right now the neck on it is flush on top of frame. Any ideas?
Re: gas tank
I just notched the bed stringer that is above the tank
69 Chevy 4x4 383 Power ![]() |
Has more rust than truck...
Re: gas tank
I also notched the bed support. Evidently if you have a wood bed you can unbolt the support, that would make the job of notching it much easier.
Re: gas tank
I'm having the same problem, I going the same route as haysonj did I have to get my bed panited anyway so the job will be done then, i guess I 'll cut a hole in the floor of the bed for the filler neck.
![]() Join Date: Dec 2008
Re: gas tank
I think most people are notching the bed support. I have seen the frame notched to accomadate the filler pipe but seems like not the best idea from a strength perspective.
Re: gas tank
Has anyone put some type of spacer under bed at each bolt on point to actually sit it higher instead of cutting bed mount rails?
Re: gas tank
Then trim and body lines are jacked up.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
