Old 12-31-2009, 08:16 PM   #1
70 aquamarine
70 aquamarine's Avatar
69 conversion to 4x4 ?
any one ever use a 73-87 frame or 88-98 frame or take axels off a 86 and bolt or weld on 69 frame ?
70 aquamarine is offline   Reply With Quote
Old 12-31-2009, 10:27 PM   #2
BarryB
BarryB's Avatar
Re: 69 conversion to 4x4 ?
I asked a similiar question awhile back, I have a 84 4wd, and was asking how hard it would be to swapp the diffs onto a 68 short frame I have. i was told it would easier to make new cab mounts and put my 68 cab and bed over on the 84 frame, after I shortened it.
But I'm looking for some more idea also, so I'll be checking in on this thread also.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 12-31-2009, 10:50 PM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Contact member "Mudder" for converting a 73-87 frame to fit a 67-72 body.
Contact member "Gene" for converting 67-72 2wd frame to 4wd.
Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 12-31-2009, 10:53 PM   #4
70 aquamarine
thanks !
Old 12-31-2009, 11:19 PM   #5
Gene
Gene's Avatar
Trevor
I actually stopped my conversion halfway through but after much research I know it can be done. www.diy4x.com has the kit to convert the front, and for the rear you can use spring hangers off of a 2wd GMC with leafs to convert the rear. I went with a 72 SWB 4x4 chassis I found on CL. I used the axels from a 91 Suburban, front bolted right in, back I had to relocate the shock mounts and spring perches.
Gene is offline   Reply With Quote
Old 12-31-2009, 11:22 PM   #6
70 aquamarine
would it be possible to use the front and rear ends from an 86 chevy truck with the 86 hanngers to ?
Old 01-02-2010, 01:15 PM   #7
70 aquamarine
does it matter what year the gmc is coud it be a chevy with rear leafs could i use the rear mounts off a 80 chevy 3/4 ton 2wd truck and then the kit for the front ?
Old 01-09-2010, 06:13 PM   #8
70 aquamarine
is their anyone who has ever finished their conversion from 2wd to 4wd with a 2wd frame and put 4wd axels under it with the right leaf hanges pics and advice but be nice thanks !
Old 01-09-2010, 09:17 PM   #9
Gene
Gene's Avatar
69-72 GMC or a Chevy w/leafs should work. Rear mounts off a 80 3/4 ton I dunno. It has to have the same dimensions as your truck at the front(rear) hanger. Chevys and GMC's with Leafs have an angled front(rear) spring hanger that allows for the wider frame than the 4wd frame.
Old 01-09-2010, 09:27 PM   #10
72freak
Rottenwood Garage Member
72freak's Avatar
I have not done it but I have a 72 that has a 2x4 frame under it and the 4x4 components from a mid 70's attached to it. They did a pretty good job, it looks good and it has been that way and driven for over 20 years.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
