Old 12-31-2009, 08:39 PM   #1
Dustydog
Dustydog's Avatar
Steering Column Wiring 70 GMC
I am installing a tilt column from a 72 Chevy in my 70 GMC. The main connector is the same. There is a long grey wire with a connector on the end that I did not have on my old column. Does anyone know where this goes?
Thanks for your help,
Dusty
Dustydog
1940 Ford 2D SDN
1970 GMC SB
2004 C5 Vette
Dustydog is offline   Reply With Quote
Old 12-31-2009, 08:49 PM   #2
john
member #16
john's Avatar
Re: Steering Column Wiring 70 GMC
The grey goes to the cluster feed on your fuse box, Tilts have a bulb rather than fibre-optic.
john is offline   Reply With Quote
Old 12-31-2009, 08:51 PM   #3
Dustydog
Dustydog's Avatar
Awesome!
Thanks!!!!!
Dustydog
1940 Ford 2D SDN
1970 GMC SB
2004 C5 Vette
Old 12-31-2009, 08:53 PM   #4
Sammy
Pics are blurry, hard to tell. But the additional wire not in the plug should be for the tranny gear selector illumination. I believe there are two types one that has a plug to fit into the one of the dash panel (fiber optic type) and the other type may plug into the fuse box.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 12-31-2009, 11:41 PM   #5
Dustydog
Dustydog's Avatar
Plug it in as John suggested and it works fine!
Thanks!
Dusty
Dustydog
1940 Ford 2D SDN
1970 GMC SB
2004 C5 Vette
