01-01-2010, 11:03 PM | #1 |
mini truck racer
1972 Brake line question
I have a 1972 chassis that is missing the front driver side hard brake line from the junction block , under the motor stand to the flex hose . I had intended to just buy a new hard line and bend it to fit , but the fitting are different on each end . I bought new flex lines and they are different from side to side . Is this a special line ? Can i adapt something fron the parts bin at the local auto parts to make something work?
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
01-01-2010, 11:10 PM | #2 |
Has more rust than truck...
Re: 1972 Brake line question
Yes you need to use an adapter, I just went through this on my rear end.
Anyplace that sells the hard line SHOULD carry these. http://www.autozone.com/autozone/cat...andName=Dorman |
