Old 01-02-2010, 11:29 AM   #1
hotrod_991
hotrod_991's Avatar
engine setup opinions
So my dad is building me a 355 while I still deployed to but in my 77 lwb. I live in MT so dont have to worry about smog or noise contol so can pretty much do what we like with it. I am just looking for some opinions on the setup. pls excuse me if I am not very detailed on all of it im new to engine building. Thanks everyone.
350 4bolt bored 30 over
All rotating stuff balanced
flo tec allum heads
valve guides
steel roller tip rockers
Rhodes hyd lifters
comp mutha thumper cam
mallor push rods
torker 2 intake
eldelbrock 650 carb
flat top pistons
full MSD ign system
TH400 shift kit
2500 stall
373 gears with posi
Anyone that is good enough to maybe estimate the HP or TQ numbers pall park style would also be apreciated. Thanks and happy new year to all
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
Old 01-02-2010, 02:40 PM   #2
dan76
Re: engine setup opinions
Suggest you include specifics on the cam....such as duration, lift, LSA or just post the cam number.
Keep safe during your deployment...
dan76 is offline   Reply With Quote
Old 01-02-2010, 05:58 PM   #3
hotrod_991
hotrod_991's Avatar
sorry bout that here are the cam specs and number also the heads:
RPM range: 2200-6100
Valve timing: .006
Lobe-center angle: 107
Intake centerline: 102
Valve lash: intake/exhaust - hydraulic
Duration: 287 intake, 305 exhaust
Duration @ .050" life: 235 intake, 249 exhaust
Valve lift: .489 intake, .476 exhaust
Lobe lift: .327 intake, .317 exhaust
Heads:
180cc intake runners
62cc exhaust runners
64cc combustion chambers
2.02" and 1.60" stainless steel valves
Hi-Performance springs for .550" lift
Five angle valve job
Bronze guides
3/8" screw-in studs and guide plates
Old 01-02-2010, 06:09 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Recommend that you stick with the Comp Cams Magnum roller rockers. I used some aluminum rollers that was supposed to be good once that crapped out in 15,000 miles. The Magnums are still doing such a good job in my stroker engine, so I did the same brand in my TPI engine for my DD.
Do you know what your compression ratio is going to be? With the aluminum heads it can be higher, but be careful to not push to high, or you will have to run higher octane fuels---more cost at the pump daily.
When you say an Edelbrock 650 carb---do you mean a Thunder AVS carb or is it a QJ replacement carb?
Torker 2 intake---are you going to run this truck on the streets or do you plan on driving where the RPMs are going to be higher, all of the time? The Torker manifolds are good at higher revs, but on the street, they faulter in traffic and low RPMs. That is why the Performer RPM manifolds were created. I see you are going to run a TH400 with a 3.73 gear set, what diameter of tires are you running in the rear? This combo will keep your revs pretty high at highway speeds. You should try to keep the RPMs at or around 2500 to 2700 as best as you can.
I am running a 700R4 tranny behind a 385 stroker engine, with a 3.73 gear set and 27" tires on the rear. I also have a 2400 stall convertor, due to the Comp Cam profile that I choose. I run at 2500 RPMs at 70 MPH and that is good for 14.5 MPG repeatedly.
Frank
piecesparts is offline   Reply With Quote
Old 01-02-2010, 08:20 PM   #5
big10ratrod77
big10ratrod77's Avatar
hey man ive wanted to try them flo tech heads on my 77 when i build it they are bout the best price for a set of aluminum heads to let me know how they turn out
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 01-03-2010, 07:56 AM   #6
hotrod_991
hotrod_991's Avatar
thanks for the advice and yea I plan on it being a street pounder. and the comp ratio is going to be 9.5:1 or 10:1 cant recall what dad said but i know i told him to keep it on pump gas even if it premium. So are you saying that torker 2 will not be what I am looking for to dd my truck? Also I went with the Rhodes hyd lifters because alot of people have told me that they are better at keeping some type of vacum with the lopier cams. Not sure what the tire size will come to but rims will be 15x8 rallies with 255/60 front and 275/60 rear.
And I will let you know how the heads work and the price is the reason I went with them cause I am tryn to stay in a 2k range for the motor build. The block is going into the machinist next week so should be able to get some progress pics soon.
Old 01-03-2010, 07:57 AM   #7
hotrod_991
hotrod_991's Avatar
oh and its a thunder series 650 carb
