Old 01-02-2010, 01:49 PM   #1
Robertw
67-72 cab on a 79 frame ????
ok will this work and if so what all will it take to make it work
Robertw is offline   Reply With Quote
Old 01-02-2010, 03:15 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: 67-72 cab on a 79 frame ????
subscribed??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 01-02-2010, 04:21 PM   #3
woodwright
Enjoying left field
woodwright's Avatar
At the very least, the wheelbase is different.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 01-02-2010, 04:43 PM   #4
mr48chev
mr48chev's Avatar
One of my buddie's ex son in laws did one and while it can be done not much fits as is.
He put a two wheel drive body on a 4x4 chassis so it might be a bit easier with a 2x4 but I don't think it will be all that much easier. He did this because my buddy had the late 70's 3/4 ton 4x4 sitting there with a bad body and good chassis.
Unless you just don't have a usable chassis I can't see the wisdom of going to all the work to make it fit. It will still be a cobbled together truck.
There are easy disk brake or five lug swaps on these trucks that take care of the things that most guys think they need to swap frames for.
Old 01-02-2010, 04:57 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you'll need a flat frame on a 2 wheel drive, unless you want to do a body lift on a 2 wheel drive.
Old 01-02-2010, 10:59 PM   #6
Robertw
thanks i was just wondering some told me it was a bolt on deal and others say no so thanks again
Old 01-02-2010, 11:15 PM   #7
Longhorn Man
no way a bolt on, even a 4X4 would requre adjusting the wheel base and a custom body lift and a whole lotta odds and ends.
Old 01-02-2010, 11:47 PM   #8
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
You need to take the mouse and click on the search button to get this to work.
It can be done, and I did a long time ago on my first truck in high school, but if you search it, there has been this same topic asked several times each year. I think if we ask Mudder, maybe we could have him make a sticky for this in the 4x4 section.
You will need to either make new body mounts or re-use them from your original frame. Also, you will have to cut the frame as the wheelbases are different. Like I said above, contact a member here that goes by "Mudder", he is a great guy. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
