Old 01-02-2010, 03:58 PM   #1
Murphy IRE
leak test brake booster
I'm trying to locate vacuum leaks on my 71 K20 400 sbc. I beleive my brake booster may be leaking.
I removed the hose from the intake manifold and hooked up a hand pump . After a bunch of pumping I was only able to pull 15 inches.
I did a search of the threads and did not find an answer to my questions.
They are:
(1) how much vac should I be able to pull on the booster? Does 15 seem low?
(2) once I pull the vac, the booster holds it fine.
Am I missing a step to the leak test? Or does my current test indicate that it is working properly?
Thanks for the help.
Murphy IRE is offline   Reply With Quote
Old 01-02-2010, 09:07 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: leak test brake booster
If the booster holds I would think its ok, the hand pump may be the reason for only 15 .
dwcsr is offline   Reply With Quote
Old 01-02-2010, 10:17 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
I would put a gauge between the booster and the check valve. start the engine, let it run for a minute and shut it off. the vacuum should hold solid.
68C15 is offline   Reply With Quote
