We Sell Truck Parts
Cruise Control Help
Bought a cruise control unit today and need to know how it works and what other parts I need. I have the vac. box with two speedo cable coming out of it. What else do I need and how does it work.
Thanks, Bo
'67 Chevy SWB 454/400 '97 Chevy Tahoe 4x4 '62 MG Midget |
It looks like you are missing the wiring, vacuum hoses, diaphragm and cable, brackets, cruise control lever, (or switch), and brake switch.
Jim |
![]() Join Date: Dec 1999
What he said above that appears to be a Olds,Buick style cruise.theres a junkyard here full of old oldsmobiles from the 60s and early 70s with that same box.
Old member
Here are two different pictures of the factory set up out of a 1971 service manual that I have.
The first is the regulator and the second is a picture of all the parts. Hope it helps
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Old member
This is the picture with all the parts.
I know it itsn't the best pictures but it is out of a manual, it's the best I could do. I need to get a scanner.
