Old 01-02-2010, 09:49 PM   #1
67chevy2wd
67chevy2wd's Avatar
I I just spent the last 3 hours doing.................
cleaning the underside of my cab with a wire wheel so I can put an undercoating on it. Worst thing I have had to do on my truck so far.
Before
After
I will post up some pics after I get it coated.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 01-02-2010, 10:04 PM   #2
echo72
echo72's Avatar
Re: I I just spent the last 3 hours doing.................
Good job man! Did you do the welding yourself? I really need to learn to weld.
Every day is a challenge. Keep on truckin!
1972 Chevy Cheyenne LWB 350 engine TH400.
echo72 is offline   Reply With Quote
Old 01-02-2010, 10:06 PM   #3
arkracing
Weekend Warrior
Worth the effort. How did you flip the cab on it's back without damaging any of the panels (i.e. Cab Corners)???
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 01-02-2010, 10:10 PM   #4
tcb-1
Nothing to see here.....
tcb-1's Avatar
but it looks soooo good!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 01-02-2010, 10:17 PM   #5
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
if you look at the floor of his truck he's got it on caster wheels so it's off the ground.
This is the reason I bought a small sandblaster using a wire wheels sucks I've had too many wires get stuck in my arms or leg.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 01-02-2010, 10:29 PM   #6
67chevy2wd
67chevy2wd's Avatar
I had my brother and two other buddies come over lastnight. We lifted the cab off by hand. I was light enough for two people to lift it. We then just rotated it in the air and set in on the casters, which are my wheel dollies that I made. I have done all the welding my self. This was my first restoration project which has been on going since 2005. It is neat to see how much better I have gotten at doing the body work over the years. The right side was my first and it looks like crap compared to some of the last panels I have replaced.
'71 GMC 3/4 ton 4x4
Old 01-02-2010, 10:31 PM   #7
67chevy2wd
67chevy2wd's Avatar
Here is a pic of the dolly. I have four of them so I can spin the pickup 360* in the garage with little ease.
'71 GMC 3/4 ton 4x4
Old 01-02-2010, 11:19 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
Looks good...went through that myself recently.........not fun
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-03-2010, 01:31 AM   #9
capev86
don't bother with rubber undercoating, moisture goes through it and it flakes off after a couple years........use zinc primer and top coat with a good poly bed liner coating such as al's liner.
capev86 is offline   Reply With Quote
Old 01-03-2010, 02:17 AM   #10
67chevy2wd
67chevy2wd's Avatar
Finished product. Turned out better than I expected. Good thing I had a friend stop by to help or else I might have been in trouble. I have about $80 invested.
This is what I used.
'71 GMC 3/4 ton 4x4
Old 01-03-2010, 04:09 AM   #11
OARNGESI
OARNGESI's Avatar
Looks like it came out really nice
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 01-03-2010, 09:44 AM   #12
big_al_71
big_al_71's Avatar
looks awesome....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-04-2010, 10:27 PM   #13
arkracing
Weekend Warrior
I saw the dolly, but I was just wondering how he got it on the dolly without damaging anything. It's pretty tough to do something like that without a cab flip setup or a few strong guys. I was thinking about doing it with my forklift, but I still would have to "roll" the cab back, which would probably damage the cab corners. I would also have to be careful that it didn't flop over to fast once past the center point.
Thankfully you had some strong guys around to do it. It is so much easier to work like that. I think it is even better than a lift - your still upsidedown with the lift, just higher off the ground.
-'66 C10 Suburban
Old 01-04-2010, 10:31 PM   #14
63chevyll
gets board easy.......
63chevyll's Avatar
how was that Duplicolor to install? meaning, does it seam pretty durable?
63chevyll is offline   Reply With Quote
Old 01-04-2010, 11:39 PM   #15
billdo
billdo's Avatar
that stuff is awsome i used in on ine but from the poof can. i love tha crap
billdo is offline   Reply With Quote
Old 01-04-2010, 11:45 PM   #16
70cst
70cst's Avatar
67chevy2wd...very nice work!
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-05-2010, 12:01 AM   #17
QKENUF4U
QKENUF4U's Avatar
ive used the same thing on both my truck beds and it works very well....
QKENUF4U is offline   Reply With Quote
Old 01-05-2010, 12:10 AM   #18
hchad18
hchad18's Avatar
Definitely the worst job ever. I did mine cab on frame, and used bed liner also. Looks good.
hchad18 is offline   Reply With Quote
Old 01-05-2010, 11:21 AM   #19
67chevy2wd
67chevy2wd's Avatar
It was easy to install. It seems like it will be durable. I personally wouldn't put it in my bed just because I don't like the finish. It isn't like line x . It will be fine for under a cab though. I rolled on what I could and then just slopped it on pretty thick with a brush everywhere else. I used about 3/4 of the gallon.
'71 GMC 3/4 ton 4x4
Old 01-05-2010, 01:31 PM   #20
D-Rat
D-Rat's Avatar
nice work. The patchwork looks good too. Glad we have no rust issues here in Arizona.
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 01-08-2010, 10:11 PM   #21
67chevy2wd
67chevy2wd's Avatar
spent a couple more hours today cleaning the floor of the inside.
first coat of Por-15. Waiting to do the second coat yet.
'71 GMC 3/4 ton 4x4
Old 01-08-2010, 10:14 PM   #22
VA72C10
VA72C10
VA72C10's Avatar
Looking great!!!
