Does anyone have more than 4 gears or is a 4 gear 700r4 as much as it gets as far a simplicity to put in???
![]() Join Date: Jul 2003
Re: Im going to need a trans and i need help.
More than 4? GM's new trucks use a 6 speed auto now. Two overdrives. Fully electronic though. What are you putting it in?
66 swb and im lookin for something thats almost bolt-in
What are you bolting it up to? You'll need an electronic lock up for the converter if you go 700R4. Later ones also have an electric speedo. Cross member will need to be moved and drive shaft will need to be shortened. Is this still considered a bolt in?
327 and that doesnt sound too bad
700R4 is what you need. Too bad you aren't closer I have an extra one.
If its free i would make the drive
Member of the longbed union.
that's a long drive. and nothing on the way there. although if you like mexican food it's well worth it. get you something with the green or red chilli nothing better.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 Last edited by ruffrida2005; 01-03-2010 at 01:41 AM. |
