Old 01-03-2010, 01:54 AM   #1
CARDOC
Rough-N-Low
here's my first z-ed frame job. i am still boxing the frame. the only question i found is how do i center the front wheels in the finder well? i am leaving as ugly as yo see it! any questions or comments welcome.
CARDOC is offline   Reply With Quote
Old 01-03-2010, 02:16 AM   #2
3r!c84
Badass
3r!c84's Avatar
Re: Rough-N-Low
nice truck i like the old beat up stock truck SLAMMED to the ground.what do u mean"how do i center the front wheels in the finder well?" what did u use upfront? airbags ?,drop spindles ?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-03-2010, 02:23 AM   #3
CARDOC
Re: Rough-N-Low
we zed the rear frame 6 inches and the front 4 inches. the tires sit back 1.75 inches in the finder well. im thinking the only way to correct this is to add the difference in before i finish the front z. but yes im addig 3inch drop spindles and bags.
Old 01-03-2010, 02:28 AM   #4
3r!c84
Badass
3r!c84's Avatar
Re: Rough-N-Low
ohh i see.you have to add the 1.75 inches to the frame to make it longer?
do all the rest of the bolts line u right?
-00 Saturn 5spd
1/4:13:90
Old 01-03-2010, 04:06 AM   #5
OARNGESI
OARNGESI's Avatar
Re: Rough-N-Low
Why the 6 inch z isnt that alittle bit much either way it looks good down low
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 01-03-2010, 04:07 AM   #6
OARNGESI
OARNGESI's Avatar
Re: Rough-N-Low
Never mind the first time i read it i thought it said 6 in the front
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 01-03-2010, 12:15 PM   #7
68GenIII
Re: Rough-N-Low
If the wheels moved in the wheel opening then the Z wasnt cut right. If its at an angle at all its going to change your wheelbase. It needs to be at a perfect 90 degree angle to the ground or perpendicular to the frame.
68 lwb to swb Cummins swap in the works. I promise it will be cool someday.
68GenIII is offline   Reply With Quote
Old 01-03-2010, 02:29 PM   #8
SCOTI
SCOTI's Avatar
Re: Rough-N-Low
It needs to be a 90° cut if there's no change intended for the overall wheelbase.
If the spindle centerline is to be moved forward to center the wheels in the opening @ the much lower height, the Z needs to be done @ an angle or material needs to be added to increase the wheelbase.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-03-2010, 02:46 PM   #9
3r!c84
Badass
3r!c84's Avatar
Re: Rough-N-Low
thank you thats what i was gona say
and is all the bolt holes lining up???
-00 Saturn 5spd
1/4:13:90
Old 01-03-2010, 10:37 PM   #10
CARDOC
Re: Rough-N-Low
ok. today not much progress, we pulled the cab and pressure washed the frame. yes yesterdays pic was a mock up with the front end at a 4 inch z. have ordered the spindles and waiting on them to be installed before we weld the front z. as far as the tire being toward the rear of the fender, this is how they are at factory height but its not noticed until it sits low. we will be adding 1.75 inches to the wheel base to fix the uglyness. thanks for everyone replys. this site with all on it is very informing.
Old 01-03-2010, 10:42 PM   #11
3r!c84
Badass
3r!c84's Avatar
Re: Rough-N-Low
nice kubota man.i work with my naber at kubota down here in fl.
-00 Saturn 5spd
1/4:13:90
Old 01-07-2010, 03:08 PM   #12
CARDOC
Re: Rough-N-Low
Whats the reason some folks are cupping the front bags in the lower control arms? no updates here im still waiting on drop spindles
