Old 01-03-2010, 01:13 PM   #1
taclem
taclem's Avatar
What Should I Keep??
I had a 72 Suburban frame given to me, I plan to take the front suspension, master cylinder/booster, and brake lines off to install on my 66 short step. What else should I keep, the third member is there as well as the fuel tank. Mine is a 292 with grandma and it really does need another gear. The frame has no engine or transmission but was an automatic. Don't know about the steering column at this time but don't think it was tilt as well if it had power steering or not.
Thanks in advance, Taclem
taclem is offline   Reply With Quote
Old 01-03-2010, 02:25 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: What Should I Keep??
If there's a tailshaft transmission crossmember I'd grab that, and any small clips and brackets that might prove useful.
Old 01-03-2010, 03:20 PM   #3
scotts62
One day...
scotts62's Avatar
Yeah take off any screws, bolts and clips you can get, there has been many times i go to our local pull-a-part just to get some screws that i need and no parts or hardware store has.
Scott
93 crew cab build
Project 62
Old 01-03-2010, 06:19 PM   #4
62gmc910
62gmc910's Avatar
If the motor mount "pedistals" are still there grab them in case you want to drop a 350 or any other even mount motor. anything else that unbolts you can scrap what you don't need later
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 01-04-2010, 12:23 AM   #5
Captainfab
60-66 Nut
I would suggest installing the rear differential from the Suburban in your truck. That way you'll have the same bolt pattern wheels front and back. I would have to agree with keeping all the nuts, bolts, screws and clips you can get a hold of. Before you get rid of what's left, post an add in the '67-'72 classifieds on here. You'd be surprised what you might be able to sell off of it.
Old 01-04-2010, 01:05 AM   #6
wild one
Registered.........
wild one's Avatar
Definitely keep the rear axle out of the 72 for the matching lug pattern, it might even have a more free way friendly gear ratio.
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 01-04-2010, 01:09 AM   #7
TwoFiftyShifter
Did you just refer to the stock 4-speed as "grandma"???
Wow.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
