Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-03-2010, 02:21 PM   #1
rennalds
Loud Humm Through Speakers
OK just finished a painless kit on my sons 71 chevy. We were going through the testing procedure where you hook a 10 amp battery charger to the system but we are getting a loud humm through his speakers everytime we power something off i.e. headlights and fan switch? Any Ideas? Oh yeah the deck is brand new also, but no amps just a head unit and four speakers. Thanks in advance for your help!!!
rennalds is offline   Reply With Quote
Old 01-03-2010, 02:31 PM   #2
cdowns
cdowns's Avatar
Re: Loud Humm Through Speakers
check that you have good grounds you can also reverse the polarity of the speakers and see if that helps
Old 01-03-2010, 02:32 PM   #3
rennalds
Forgot to mention that it even happens when the radio is powered off. It kind of sounds like when a microphone goes haywire when soeone get to close to it.
Old 01-03-2010, 03:10 PM   #4
tcb-1
Nothing to see here.....
tcb-1's Avatar
is it a high pitch squeal? if so, that is direct short somewhere. time to break out the voltage meter....
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 01-03-2010, 03:33 PM   #5
rennalds
Its more like a bass hummmmmm.
Old 01-03-2010, 04:26 PM   #6
tcb-1
tcb-1's Avatar
a bass hum, interesting. with the ignition off, correct. are you running any type of motorized devices on ignition, like an electric fuel pump or electric fans (cooling, etc?)
is the head unit new or from before you rewired?
Doug
Old 01-03-2010, 04:51 PM   #7
rennalds
head unit is new, nope the harness had wires for all that stuff but we just crimped them off?
Old 01-03-2010, 04:52 PM   #8
rennalds
we turned the headlights on and every thing was fine. The loud humm seems to happened when we power something off, I also forgot to mention hummm is also present with the key switched to accessory, but it is very faint.
Old 01-03-2010, 05:15 PM   #9
tcb-1
tcb-1's Avatar
that is an interesting one. in my 20 some odd years of installing, I've never heard of that one.
can you try to run a secondary ground? sounds like when the lights are activated, the chassis ground strengthens somewhat. I still think it's a faulty ground. are you running the stock ground through the original wire harness?
sorry for all the questions, but it's one of those "not so easy to answer" questions!
Doug
Old 01-03-2010, 05:35 PM   #10
rennalds
No problem at all thanks for all your help. The ground on the head unit harness is grounded to the dash right now, should I try to run it to the chassis. It also happens when we turn off the fan switch.
Old 01-03-2010, 05:37 PM   #11
rennalds
one other quick point we didnt use the brace for the back of the unit because it was kind of cramped does the brace serve as a secondary ground???
Old 01-03-2010, 05:50 PM   #12
tcb-1
tcb-1's Avatar
I don't know how many head units I installed over the years that didn't have a rear brace. short of jumping speed bumps daily, I never use the rear mount brackets. they are a pain in the butt. however they are a GREAT theft deterents!!! the braces should in no way be a part of a secondary ground connection.
I'd try running a ground directly to the chassis. your ground connection for the headlamps and heater fan are tied directly to the chassis/frame.
give that a whirl and report your findings.
Doug
Old 01-03-2010, 06:08 PM   #13
rennalds
good stuff I'll try that and get back to ya either way thanks again!!
Old 01-03-2010, 07:35 PM   #14
AceX
>130dB Moderator
AceX's Avatar
Something is sending a signal to the chassis. Take the battery charger off and see what happens. We have a similar issue in my dad's '06 except we get digital tones through the speakers. While the truck is off. Weird right?
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 01-05-2010, 07:22 AM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
is the charger an automatic type ,that may ajust amps as needed ,may be noise from the charger? try with a batt if you can, does the truck or did the truck ground the one side of the speaker before?? new radios don't ground out one side anymore ,make sure only the power ground is grounded not speakers
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-05-2010, 02:45 PM   #16
rennalds
I am using the battery charger to make sure there aren't any shorts in the newly installed harness before connecting a battery. I was sort of thinking along your lines motornut, that the charger might have something to do with it because it only happens when I power stuff off. The main thing keeping me from hookin the battery up is that this happens even when the stereo is off?????? I know the radio has both switched and constant power, just a little worried I'm gonna burn the whole damn thing down lol. The stereo and all speakers sound good when its powered on and nothing else is messed with. Am I risking screwing something up if I connect the battery?
Old 01-19-2010, 01:56 PM   #17
rennalds
the verdict is finally in, it was the battery charger i was using to check the system out, once the battery was hooked up everything worked like a charm. thaks so much for all ur heklp and input!
Old 01-21-2010, 11:12 PM   #18
rare86
Extended cab fanatic
rare86's Avatar
Just for reference, most battery chargers overcharge when connected with out the load from the battery. Ive seen as high as 16VDC on some of them. Most electrical systems are somewhat tolerant of this, but some are not and the results can be disasterous. Glad you got the issue solved tho. Have fun
If it has a motor, it has my attention.
rare86 is offline   Reply With Quote
