![]() Join Date: Aug 2008
Van tilt column, key on dash w/ wiring adapter
$125 + shipping.
The column is good and tight and the tilt mechanism works good. Included is the tilt column, plastic horn ring that mounts under the wheel, steering wheel nut, rusty turn signal arm and shift arm, neutral safety switch and adapter to go from the flat van wiring connector to truck half round connector. Basically all you will need to get going would be a steering wheel, gear indicator and tilt lever, if you were OK with the rusty turn and shift levers. Last edited by WIDESIDE72; 01-04-2010 at 07:17 PM. |
Re: Van tilt column, key on dash w/ wiring adapter
Last pic
Ttt
![]() Join Date: Dec 2008
How about 125.00 shipped to 36027?
I will take it. PM me with payment info.
Sold to brian mac
