Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 01-03-2010, 04:56 PM   #1
WIDESIDE72
WIDESIDE72's Avatar
88-98 3/4 ton 8 lug 4.10 posi 9.5" Rear Axle, 1 ton SRW springs
I pulled this axle out of a 93 3/4 ton 4x4 since the parts truck I had had a full floater rear axle and is "heavier duty". I bought the truck it came out of not running and swapped this axle out beofre I ever drove it, so I cannot say whether or not it mad any noise or not. I did pull the rear cover to check that the ratios between the two axles were the same before swapping, and nothing looked out of the ordinary. I did not think to take a pic at the time. Prospective buyers are welcome to pull the cover or do anything the need to do for inspection before buying. There is a little leakage evident at the pinion seal. There was still plenty of fluid in the axle when i pulled the cover.
NO OIL CURRENTLY IN THE AXLE
No shipping.
$150 for axle and drums, no wheels $50 for mid 80's (non rally) steel wheels and old tires that hold air for a week or two
I also have the following:
Rear springs out of the donor truck. It is a 1 ton single rear wheel. I believe they are 56" eye to eye. $100 pair
Complete 8 lug 2wd front suspension. $150 You pull al the pieces, or I can use my "hot wrench" (torch) to cut the frame at the firewall.
1994 Bare single cab and doors andLWB bed. Pics under "Parting out 1994 Siverado Reg Cab, no front clip, engine trans seat, interior/ guages'" in this same forum
The truck has not been wrecked. I bought it as a parts truck w/ no title.
Package deals available
WIDESIDE72 is offline   Reply With Quote
Old 02-13-2010, 12:37 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: 88-98 3/4 ton 8 lug 4.10 posi 9.5" Rear Axle, 1 ton SRW springs
ttt
Old 03-22-2010, 09:50 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
ttt
Old 02-16-2011, 08:38 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
ttt
Old 04-02-2011, 06:14 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
offers?
Old 04-29-2011, 01:36 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
ttt
