Old 01-03-2010, 05:39 PM   #1
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
3.08's or 3.42's
Ok i'm looking for better highway miles. I thought I had 4.10's and comes to find out they are 3.73's I still get bad highway with the 350/350.
what I want to know is what you guys think about 3.08's with about a 28-29 tall tire. that will put me in the 2400-2700 range with my trans.
Guys with 3.08's comment please.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 01-03-2010, 05:59 PM   #2
62gmc910
62gmc910's Avatar
Re: 3.08's or 3.42's
you need to find your engines sweet spot . Find a quiet level road and run the truck up at 1/4 throttle til you hit drive then feather out of the pedal till you find the rev range that everything runs free.
Most late 70s 350 trucks ran 3.08 gear
3.42 was common with 700r4 trucks
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 01-03-2010, 06:06 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
My 1960 GMC came stock with 3.73's. After I installed a 350/350 I switched to 3.08's and it was sweet on the highway. I commuted 72 miles round trip a day in it for many years and could turn up 16+ mpg if I didn't use the back barrels. For my setup it was right in the torque curve. Once I went to a 4 speed manual I went to 4.09 gears and traded mileage for fun. I was running 255/70-15 Radial T/A's with the automatic which list at 29.10" tall.
Old 01-03-2010, 06:13 PM   #4
ruffrida2005
Sounds good guys, wish I could drive the truck now but it looks the way my pic does. I might trade Gage my gears for some 3.08's if he wants to.
Paul
Old 01-03-2010, 08:31 PM   #5
Winola73
You'll need to trade carriers too. 3.42 and "higher" (numerically lower) use a different carrier than the 3.73 and lower (numerically higher).
With a TH350, 3.08's and 235/75R15's your RPM at 55 MPH should be right at 2100, maybe a little higher with converter slippage but nowhere near 2400 with 28-29 tall tires. Overall diameter on a 235/75R15 is 28.88 but the actual "rolling" diameter under load is 27.145.
Here's a website with some great calculators for tire diameter, speedo gears, etc.
http://tri-5.chevyrides.com/speedo.php
I have an '86 D150 with a 318, 727 trans, 235/70R15's and 2.94 gears and it turns just about the same. It's nice on the highway but I sure wish I had an extra gear in there down low because it's a real slug around town. Due in no small part I'm sure to being a Dodge....
I'm considering putting a 3.08 in my '66 C10 but with the stock 4 speed. I'll have a 355 built for low and mid-range tq. in front of it and I'll be running 235/75's on it.
Winola73 is offline   Reply With Quote
Old 01-03-2010, 08:50 PM   #6
ruffrida2005
Thanks for the info Winola I knew I had to swap carriers also.
I got on Richmondgears website and at 70 MPH with 3.08's they had me little over 2400RPM
I will keep the 3.08's for now till I can get a set of 3.42's for a little better low end.
Paul
Old 01-03-2010, 09:12 PM   #7
Winola73
I missed the 70 MPH part...
I wish they made a 3.23 for the truck 12 Bolts.
