Drivers door hinge pins?
I recently installed new cab mounts and discovered the drivers door is also sagging. Are we able to buy new pins and how much trouble are they to install? Thanks for any help.
Re: Drivers door hinge pins?
Most vendors have the repair pins. And seen them in the help section at Autozone on a card. Hardest part is removing the hinge from the door. As you need to work on a vise.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
