Old 01-03-2010, 07:07 PM   #1
kevintm2
67 fleet short box wood
Im doing a frame off and have painted all pieces and finished sealing the wood. I'm ready to start assembly but need to know where to start, are there any tricks? I've invested to much to screw this up :-)
kevintm2 is offline   Reply With Quote
Old 01-03-2010, 07:24 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: 67 fleet short box wood
I'll be doing my longbed soon so I'm interested as well...have you checked Mark-K or GMC paul's websites for info?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-03-2010, 07:27 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
Just checked Mark-K and they give the instructions free when you buy something....maybe someone here can scan them...
Old 01-03-2010, 07:32 PM   #4
nibs
JRods Garage
nibs's Avatar
Im gonna say it depends on how you are planning on storing this truck. You could go out and get a real nice hi-gloss varnish, if the thing only comes out on nice days. Im not sure how well they do with weather. There has to be a place that makes a weather resistant hi-gloss finish...
nibs is offline   Reply With Quote
Old 01-03-2010, 07:41 PM   #5
kevintm2
VA72C10- Thanks for the GMC Pauls site. Good info that will also help when I do my 55 in the future.
nibs- I used an oil based marine gloss spar urethane that Im hoping will weather well. Truck will be exposed to Arizona sun but little rain.
Old 01-03-2010, 08:40 PM   #6
rsavage
rsavage's Avatar
Just as an FYI,
If the wood finish is exposed to harsh sun (UV), the finish can lift in a short time. When I restore boats, I put a minimum of 10 coats of good marine varnish like Epiphanes (has UV blockers) on the decking. Then, if exposed to harsh sun for a season, another single coat is done at the beginning of the next boating season.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-04-2010, 10:08 PM   #7
kevintm2
rsavage- what grit do you sand between finishes? I'm using 220 and on my third coat now.
Old 01-04-2010, 10:29 PM   #8
Sammy
Two years ago I put 5 coats of marine varnish on my floor. And the truck is mostly garaged. This summer I will be applying at least 3 more coats. And I just lightly sanded the wood between coats. The marine stuff is really thick and they don't recommend thinning it either. If I put 10 coats of the stuff i got on it, it would have been 1/8 inch thick. But overall it has held up real well. Very seldom seen much more than the sun and a few sprinkles once or twice and overspray from pressure washing the truck I guess.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 01-04-2010, 10:34 PM   #9
Sammy
pic
Old 01-04-2010, 11:28 PM   #10
rsavage
rsavage's Avatar
KevinTM2,
220 works well. The last couple of coats I use a 320. Tack well between coats and use a real bristle brush with real varnish. bristle brushes are expensive compared to man made and you don't let them dry out - they are hung in thinner. Dust is your enemy in varnishing as it takes awhile to "set". Any dust in the air will find its way to varnished wood.
Sammy your bed looks great.
1961 C1 Corvette
2021 Durango RT 5.7
Old 01-04-2010, 11:35 PM   #11
rsavage
rsavage's Avatar
Here's a photo of the Chriscraft 17' Utility I restored. Photo was at the Clayton Boat Show. I sold it last year. Currently restoring a 56 Lyman.
1961 C1 Corvette
2021 Durango RT 5.7
Old 01-04-2010, 11:45 PM   #12
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
I used 6 coats of Man o' War Spar Varnish and I used steel wool between each coat. Came out great.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 01-05-2010, 07:46 PM   #13
Sammy
Thanks. I 2nd the dust issues. And don't shake the varnish, stir let it set for a few minutes before coating.
Old 01-05-2010, 09:23 PM   #14
71 super
71 super's Avatar
Original question, place the side pieces along the wheel tub first, then the section with the cut out, and then work to the middle, the boards will have alot of space so the middle is easy. This is for a fleetside by the way, step side lay boards from side to middle. Good luck.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
