de arching springs
i have been looking around at ways to lower my truck, i might have found a way, a shop says that they can de arch my leaf spings, has anyone tried this, and how much of a drop can i get?
Slugish
![]() Join Date: Jan 2005
Re: de arching springs
have had mine dearcked twice because Iwas'nt satisfied with the stance the 1st time . honestly , Idon't think you can dearck over 3-4 in. Mine is dearcked approx. 3in. with shackles & hangers another approx. 4 in.
I had a set dearched on a 94 that I had. I agree with Slugish I don't think you would want to go very much with it. We also went 3"
I know the pieces fit
I don't know much about this except something I read a long time ago and I forget the details. Are the spring-packs heated to lower them? Is this generally considered a safe way to go?
how do they ride?
Happy to be here
![]() Join Date: Mar 2000
How much do they charge to de-arch the springs? It would have to be pretty cheap to make it better that a shackle and hanger or flip kit.
I see it as a waste of time and money.
purely my opinion, but if it smooths out the ride, I think it would be worth it. Especially with my heavy half springs. there seems to be a fine line between beat you to death and too soft and bottoming out by removing leafs.
#8 | |
De arching springs typically will stiffen the spring.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
Well
if that is the case.....I will have to agree with Ken ![]()
Insert Witty Text Here
Western Chassis makes 4" drop leaves, which is a possible alternative.
Slonaker |
The place that did ours only charged like $40 for both sets of springs if IIRC. It was way cheap, and fast. I didn't take them up there so I didn't see how they did it. The ride wasn't that bad. Wasn't any worse than any other lowered truck I rode in. It was rough, but some of that was attributed to the 20" wheels that were on it too. I don't think I would do it that way again, just because the market has so many options now than they did before when we had it done.
#13 |
I have 2" shackles and new springs - can't use hangers on the Blazer and a flip is lower than I want to go.
I need to find someone local who can do this and see what's involved. My last option would be custom springs. |
#14 |
Divorced .....WITH KIDS
I had a set dearched several yrs ago. They took the springs out and put them in a press aond flattened them out. It cast around 200 bucks. Droppedtruck about 3.5 inches. I went this way bc of convenience. All i had to do was drop truck off and pick up. Truck didnt ride bad . The mechanic said he rolled the springs for a better ride . Where the spring met the shackle it had a small curve.
1969 GMC SWB 1975 Chevy Malibu 80k 1963 Ford Galaxie 63k (inherited) 2005 Nissan Armada (wife's idea) |
#15 |
OL BLUU
![]() Join Date: Mar 2004
I had/have mine dearched 4"... with a 2 drop shackle installed before my current set up. It road better to me than it did when it was at stock height.
More Drop and pics... whatch'a think?: http://67-72chevytrucks.com/vboard/s...d.php?t=249927 My recent 2wd Blazer progress thread: http://67-72chevytrucks.com/vboard/s...d.php?t=393427 http://67-72chevytrucks.com/vboard/s...d.php?t=394870 |
#16 | |
I was thinking about going this way myself. I wanted to use new parts so maybe just buying some new lowering springs would be the best way to go. My only fear is that my 28 year old, 200k plus mile springs are already sagging quite a bit and the new lowering springs might only put me down about an inch?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
#17 |
My rear springs are new replacements from Husky and they did pick the truck up considerably. I'm not going to tweak the rear until I get the 325's on, then I'll better know what it needs. It may not need anymore than removing the helper spring. I hadn't heard de-arching discussed in a long time and wondered what the consensus was on it.
#18 |
I was thinking the same. Has anyone ever tried shortening the #3 spring on each end and seeing if it looses some arch that way.
I have aquired a 4" kit which includes relocating the front spring hangers and longer shackles. As everyone says you will want just a little more. I have been looking at one ton springs also. Haven't measured them up yet but I have noticed that the front spring hangers on the like 1998 one ton are higher on the frame than my 80 c-10 stock. Kind of the same is what my kit came with. They are a thicker spring and three springs. But if I only used one and kept my axle on the bottom I could always raise it up with a spacer. |
