Old 01-03-2010, 09:00 PM   #1
jackyl9999
jackyl9999's Avatar
exhaust suggestions
I am needing to decide on the exhaust setup for my nearly completed project. Its a 70 gmc swb. Has a mild 350. Any suggestions. I like flowmasters but can get half my money back on dynomax. So I am torn. Videos would help if you have any!
Thanks,
Steve
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 01-03-2010, 09:33 PM   #2
bigsnookmaster
bigsnookmaster's Avatar
Re: exhaust suggestions
I run Dynomax Super Turbos with a 3" mandrel bent exhaust with an x-pipe, and I like them better than any other muffler. Theyr'e quiet and make tons of power. My .02
bigsnookmaster is offline   Reply With Quote
Old 01-03-2010, 09:57 PM   #3
67ss&99ss
Andy
I have a regular 2.5" 40 series on my C/10 that are dumped under the bed. It sounds pretty good, and isn't loud at all in the truck going down the road. I have dumped super 40s on my 'Cuda and they have a much deeper sound due to the larger case size. I run dumped one chamber flows on my 67 and 99 Camaros and they have the best sound to me, but they are loud in the car and going down the road. If you want the most aggressive/loud exhaust then one chambers are for you.
cuda
View Video on FQuick
67 Camaro 350 with 1 5/8 headers, regular 40 series. This engine/exhaust are now in my truck.
67 Camaro with the 406 in my sig. 3", x pipe, dumped one chambers
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 01-03-2010, 10:32 PM   #4
jackyl9999
jackyl9999's Avatar
What is the drawback or benefit of doing duals into a single muffler?
Cuda sounds awesome btw.
1990 K1500 Daily
Old 01-04-2010, 12:09 AM   #5
67ss&99ss
Andy
Thanks.
I would think it would be more restrictive since you are trying to put twice as much volume through the same amount of space.
Old 01-04-2010, 02:12 AM   #6
wzuke
wzuke's Avatar
I have Dynomax mufflers - they sound like a farm tractor.
wzuke is offline   Reply With Quote
Old 01-04-2010, 05:00 AM   #7
Irishpilot
I have LT headers to 2.5" duals w/ X-pipe going through Magnaflow mufflers under the bed. It gives it a mellow 70's sound, but has some bite to it under WOT. Here is a video of the truck, ignore the sound of the compressor :-)
Duals to a single muffler is similar to how newer vehicles are setup. That is a more restrictive setup, which will cost a little on power.
1971 C-10, 406ci, restoration begun!
406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners.
Irishpilot is offline   Reply With Quote
Old 01-04-2010, 09:13 AM   #8
fdbdw
fdbdw's Avatar
Long tube, 2.5 pipes, super44s exit before the rear tires. I love it, nice and deep, not to loud like some suggest, sounds great at all levels
fdbdw is offline   Reply With Quote
Old 01-04-2010, 11:48 AM   #9
vectorit
What?
vectorit's Avatar
I'm running dual FM series 70's, stock pipe diameter, and a H pipe.
The tailpipe exits behind the rear wheels, and the truck is nice and quiet but sounds like an old car/truck should sound to me.
I personally want to hear my drive train, and listen to the radio or people talk while I drive.
All a matter of taste.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 01-04-2010, 12:02 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
I'm running long tube headers with Summit Turbo muffler's, 2 1/2" pipe exiting in front of the rear wheels. Nice mellow rumble.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
