01-03-2010, 10:40 PM | #1 |
how low will this put me
i want to bag my truck but do it a cheap as possible to get as low as possible. how low will i be if i step notch the rear, still use trailing arms, i already am using ece drop member and just bag the front with drop spindles. if you are running this set up or have pics of this set up post em.
01-03-2010, 11:13 PM | #2 |
TILT COLUMN GURU
Re: how low will this put me
Check this out.
http://67-72chevytrucks.com/vboard/s...d.php?t=365580
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
01-03-2010, 11:19 PM | #3 |
i was thinking a bigger notch in the back. what all would it take to lay or get petty dang close to laying without getting to crazy?
01-04-2010, 02:34 AM | #4 |
someday it will be done!
The problem with the trailing arms is that they hit the frame rails long before the frame hits the ground.Here's a pic of my set up with a 2 3/4" c notch and bag in place of spring.If you moved the bag say behind the axle,you could get 2-3" lower with a bigger notch,but unless you make a special notch to clear the trailing arm,you'll hit the frame.I guess it comes down to how bad you want to keep the arms how bad you want to plant your frame,and how much work you really want to do.
Here's the pics.The frame is about 6" off the ground aired down.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
