Old 01-03-2010, 11:23 PM   #1
69pickupnyc
Unhappy rear and trany question
has any one put a 308 rear with a 700r trany and did it have a negative effect on gas milage? I put a 700r trany in my 1969 short bed and did not have to cut the drive shaft.
69pickupnyc is offline   Reply With Quote
Old 01-04-2010, 12:11 AM   #2
americanmusc1e
americanmusc1e's Avatar
Re: rear and trany question
I have a 700r4 and 3.08 gears........ and, yes, my mileage is worse than the old 3.08 and TH350 combo................i'm switching to 3.73's soon
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 01-04-2010, 11:24 AM   #3
69GMCLonghorn
69GMCLonghorn's Avatar
It depends on what size tires you're running, engine set up, etc... If you have zero power under 2000, you'll probably get worse mileage. My thing is, if you don't have the high gear, you can't use it, even on downhill. So you might run 3rd gear now and then. The torque converter should still lock up, then when you're on the level or downhill, upshift it and get the better mileage. Just speaking from experience with too much gear and not enough engine.
69GMCLonghorn is offline   Reply With Quote
Old 01-04-2010, 05:24 PM   #4
powell72
powell72's Avatar
It sounds like you could use some more gear or stay in third a little more. I've always heard don't run a 700 in overdrive under 1800-2000 RPM. That overdrive drum is small and doesn't handle the heat well.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-04-2010, 06:48 PM   #5
69GMCLonghorn
I have heard that, too... 4L60's are the same way. My '95 actually had a decal in the door jamb that said something to the effect of "don't lug it"... My thought is, design the dang thing so it pulls back into 3rd when it should and we wouldn't be having this discussion! I manually shifted the '95 until the bushing in the steering column was shot...
